#19 |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
I'm just looking for the day that algae grown bio-fuels become economically feasible.
Eventually the cost of oil will make everything competitive as demand increases. |
#20 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
Yes, price drives competition.
#21 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
technology will solve the problem another way |
#22 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Not to play any political sides, Toyota Yaris car thread here...
![]() But, this is the classic false left/right paradigm. They (US Presidents) are all the same. The problem is a crony corporatocracy... the symbiotic relationship between corporations and government. Our elected officials working with corporations in subsidizing corn to profit for big oil business and the government plutocracy while claiming ‘green’ and ‘eco-environmental’ safety to the masses. Sometimes it seems closer to a Kleptocracy... ![]() It’s all a big lie. Presidents are only a ‘spokesman’ by design. Cheers...
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#23 | |
![]() ![]() ![]() ![]() ![]() Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
![]() I grow weary hearing some mebers of congress crying that the federal government wont do this or that or inact this or that law. They are the federal goverment! It's like someone complaining that they are barefoot when they refuse to put on their own shoos. |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
wouldn't a 15 > 20 % ethanol mix make for poorer mileage ? Especially in the winter . Wonder if there'd be an addtional loss of 2 > 4 miles to the gallon . How's that going to help the pockets of consumers . It's a no win situation . Darned if you do , damned if yeh don't .
#25 | |
but the US corn producers will make mo' money. Last edited by 127.0.0.1; 05-06-2010 at 02:53 PM. |
#26 | |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
Here's some more info about ethanol vs MTBE as an oxidizer http://www.seco.cpa.state.tx.us/re_ethanol_mtbe.htm |
#27 |
#28 |
Ethanol in gasoline both reduces miles per gallon, because it contains less energy per gallon than gasoline, AND raises octane. By the cockamamie system we use in the U.S. to post octane numbers on the gas pump, (Research Octane Number + Motor Octane Number)/2, blending 10% ethanol by volume raises the octane number by approximately 2-3 over the base gasoline's value. Not a huge boost, but noticeable.
In many other countries the Research Octane Number is posted. That's obtained in a special variable compression low speed engine breathing cool air. The Motor Octane Number is measured using a higher intake air and coolant temperature, with the engine running at a higher speed, and is more representative of conditions in a car engine. It's a good bit lower than the Research Octane Number, and the spread between them is a rather variable number called the fuel's "sensitivity." |
#29 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Mechanics in my area say there really is no problem with using the current mix of ethanol which is up to 10%. So far, only Chevron is adding it and have placed a sticker on their pumps indicating such. Phillips/Conoco told me they have no current plans to add this to their fuel. So I'm still not sure if this will be federally mandated at some point or not. All I know is I am currently going to only Phillips to get a top tier fuel. I had a terribly destructive experience with MTBE many years ago, which Chevron only paid for the repairs after the Toyota dealer said we've got the fuel out of the vehicle and it's the cause of all the fuel system damage. Finger crossed ethanol stays out of our fuel for the most part
#30 | |
Audio Junky
#31 | |
Audio Junky
One thing I noticed... Before Oregon did E10, they had much higher gas prices than Washington. After E10.... they have similar, or cheaper prices (despite the fact they have to pay a person to pump gas for the customer...its a law). Eth content seems to drop the cost, and I suspect the drop in cost might actually be bigger than the drop in performance in real world results. |
#32 |
#33 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
the only problem i see for ethanol is tuner guys with injector duty cycles that are already maxed out.. a WRX guys for example with a cobb tune are already nearing 100% duty cycle with their injectors.. now having to inject another 5% more to run E20 might mean you could lean out or the injectors could fail.
#34 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
You can't really find 10% around here any more, it's all 15% or higher. If the station has a higher price you can usually find 10%, though.
#35 |
Sudbury....I went through there on my motorcycle 10 years ago. I noticed distorted rocks on a cliff and found out later you were hit by a giant meteor eons ago.
#36 |
| FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! | STC | Fuel Economy Forum | 12 | 04-16-2010 11:21 PM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| A related thread to "What's Next for the Yaris" (Ethanol) | Goose | General Yaris / Vitz Discussion | 15 | 06-05-2007 04:15 PM |
| Consumer Reports on Ethanol | Driver | General Yaris / Vitz Discussion | 6 | 09-01-2006 11:21 AM |
| What effect will 10% Ethanol have...... | Driver | General Yaris / Vitz Discussion | 18 | 08-29-2006 09:03 AM |
