Old 05-22-2010, 09:58 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by auxmike View Post
@silkysmooth;
Are'nt you the same member who stated the OEM Thai filters would damage the cars??
I've been using them since day one. 25k miles later, and no probs.
And this has what to do with coolant? I was having problems after an oil change getting oil pressure with the thai filters I bought - On two separate cars in multiple instances. Thats more than coincidence or bad luck. Just relating my experience - doesnt mean it applies to everyone/ situation. I guess I could shut up and say nothing. That may comfort the paranoid types or the Iconoclast that arent comfortable in their own skin ;)
Old 05-14-2010, 10:51 AM   #2
TheSilkySmooth
My radiator hose (lower) is cold even after I get off the interstate and sit a minute. If I let the car sit running, the fan will eventaully come on after 10 mins and the lower hose will get hot. Maybe t-stat but these cars run cool I guess and have a hot t-stat. Maybe 195? I would LOVE to put in the TRD 180 unit but I think they pulled it from the catalogue as it was not emissions approved?
Old 05-20-2010, 11:34 AM   #3
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
it sounds to me like a leak in the "engine head"(gasket) or a leaked pump.also check if your oil level has suddenly rose up with no apparent reason after the vehicle is idle.
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 05-20-2010, 02:30 PM   #4
Hershey
just checked the 2010 and it's the orange / brown color . There's about 7,000 miles on it . This seems normal . Hopefully , not all our YARII have coolant leaks . Very doubtful .
Old 05-20-2010, 05:54 PM   #5
TheSilkySmooth
Thanks, Man. After adding a pint of distilled HOH over a week when cold in the morning, the level has stabilized the past 3 days - not loosing any. Hope it was just the dealer checking the coolant when HOT and spilling some out or making a air bubble that I worked out ? ;) All was well before the 30K Toyota dealer service.
Old 05-20-2010, 11:03 PM   #6
Hershey
if you get the nerve you could look at some used YARIS or even a new YARIS to check under the radiator cap for the orange - brown coolant . That's what we did . Sure it peed off a few salesman that went and got the key so I could pop the hood to a look around as if we were possibly interested in purchasing them . All for the sake of our YARII . Though it is a bit embarassing . Wonder if the coolant in the 2004 > 2006 XBs are of the same color . Guess I'll have to check out a few used XBs now .
Old 05-21-2010, 05:39 PM   #7
Lucas13
Drives: 07 Yaris LB
I checked my coolant from the readiator and looked brown and rusty too, I took a white napkin and let it absorb some of the coolant and the luquid looks pink as in the reservoir, so maybe is the black background that make it look rusty.
Lucas13 is offline   Reply With Quote
Old 05-27-2010, 08:26 AM   #8
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I think Lucas13 is on the right track. I checked the coolant in my 09 and in the overflow tank it was bright neon pink and under the rad cap it was rusty brownish orange. I too think its the darker background changing the color. I didn't think to blotter test it like he did though.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
when car idle coolant goes to 200+ degrees N9QGS DIY / Maintenance / Service 7 05-09-2010 11:14 PM
Check your coolant bottle UTVitz DIY / Maintenance / Service 13 12-16-2009 09:13 PM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
30K throttle service jaggurnaut DIY / Maintenance / Service 39 09-11-2007 08:34 PM
