Old 05-13-2010, 12:16 PM   #1
mrb3990
Drives: 2010 Yaris Blcksandpearl sdn
I think it is just a function of a person's personality. I never let my Yaris go under 2 bars. I'm way too scared of damaging the fuel pump (if I were ever to run out of gas), even though I don't even know if that is possible on a Yaris. I just know that letting your fuel tank go dry is not good for your car and that is enough for me.
mrb3990 is offline   Reply With Quote
Old 05-13-2010, 12:41 PM   #2
Rain
help! my Yaris shrunk!
Rain's Avatar
I never let mine go beyond the three bar. Set a bar limit. I think that's the simplest way to do it. If you go past the limit that you set, then you know it's time to fill up. No need to wait til your completely out unless of course you're one of those people who intentionally not fill up so they can get "free" gas.
Old 05-13-2010, 01:01 PM   #3
toad
toad's Avatar
Drives: street-legal go-kart
i've got a 6 year-old who likes to constantly watch the fuel gauge. i think it's the highlight of her time in the car to keep daddy informed of how many 'bars' of gas i have left! best system out there
toad is offline   Reply With Quote
Old 05-13-2010, 01:34 PM   #4
Rain
Rain's Avatar
awww how cute
Old 05-13-2010, 01:16 PM   #5
tomato
tomato's Avatar
@ OP : yeah, the last 2 bars don't last as long as the others. There are some threads on here about that. When it starts blinking, start looking for gas!
Old 05-13-2010, 01:30 PM   #6
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
Usually when you get to the last bar you have about 1.9 gallons of gas left, this is when it is blinking normally, when the bar starts to blink rapidly you have 1.1 gallons of gas left, so basically on how you drive you have about 30+ miles left before you go on E, but yea i agree there should be some sort of beep or noise notification letting you know your fuel is low, like the ticking time bomb seat belt noise lol
Aothachos is offline   Reply With Quote
Old 05-13-2010, 02:14 PM   #7
drew999
Drives: 2008 yaris
i'm not blaming toyota or making excuses. I'm having a go at myself. i'm clearly a moron
drew999 is offline   Reply With Quote
Old 05-13-2010, 02:44 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
When the last bar first starts blinking on mine, it takes 10 gallons to fill it. If it's an 11.1 gallon tank, that's 1.1 at first blink.
Old 05-13-2010, 02:51 PM   #9
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Lmao at title
Originally Posted by sw07gt
Old 05-13-2010, 04:45 PM   #10
mryaris
Drives: 2010 Carmine Red hatchback
My Yaris is the same way. I keep records of all my fill-ups and know that my mileage is usually 38-40MPG, so I monitor the trip odometer as well as the fuel guage. Knowing that it takes 10 gallons to fill up when I hit the last bar, I look at the odo and see where I'm at. That let's me know how much further I can go before I run out.
For example, on my last tank the last bar started flashing at 392 miles, so I knew I was getting around 39 MPG that tank and could confortably drive another 20 miles without fear of running out of gas. Generally speaking, I don't fill up until the last bar starts flashing.....I see no reason to fill up earlier than that. One perk of driving a Yaris is not having to fill up so frequently, so why do it voluntarily?
As for the OP, I have no real criticism for running out of gas, but would suggest (as others already have) that you pick a point to fill up at.....whether it's the second to last bar or a certain mileage and stick with it.
mryaris is offline   Reply With Quote
Old 05-13-2010, 04:59 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
yup and if you mod don't forget that may impact your results.
Old 05-17-2010, 11:35 AM   #12
Fifthrate
Geek
Drives: 2007 Red 3-Door
Yea, it took a little time to get used to but I would always catch it just as the bar started blinking. The first time was harrowing until I realized that the blinking did mean I was low but usually I had around 12-15 miles left of fuel which was usually more than enough to find a gas station. These days I usually don't let it get lower than 2 bars.
Fifthrate is offline   Reply With Quote
Old 05-13-2010, 02:33 PM   #13
tomato
tomato's Avatar
^ So you were wondering if you're the only one?
Old 05-13-2010, 02:57 PM   #14
MadMax
MadMax's Avatar
Whereas I commend you for wanting to keep your eyes on the road and the vehicles around you, I am sure there are plenty of opportunities in Los Angeles to check your gas level with all the red lights and stop signs. Make it a habit to scan your gauges when you're sitting and make a mental note that it goes from two bars to one flashing bar in one step, so once you see that flashing it's time to get gas!
I for one tend to drive the tank near fumes but since I track my consumption and range on a regular basis I have a pretty accurate idea of how far I can push a tank of gas. It's both an art and a science...
Cheers! M2
Old 05-13-2010, 05:23 PM   #15
bronsin
bronsin's Avatar
I fill up when the tank hits half full. Never ran out of gas in over 30 years. That means buying gas every two weeks.
Old 05-13-2010, 05:49 PM   #16
mryaris
On your next tank, fill up when the tank hits half empty and see if it helps. ;)
Old 05-13-2010, 05:24 PM   #17
Rain
Rain's Avatar
I think I kinda get you now.. do you forget to fill up because you don't have to do it as often as you did with your other cars?
Old 05-13-2010, 05:43 PM   #18
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
Aothachos,
So there is two blinking modes and there is not a mode where the gauge is blank before running out? Cause I have reached the normal blinky and I was always under the impression you have 1.5 gallons left. si I figured I could go about 50-60 miles cause I get about 38 mpg, but after about 15 to 20 miles it starts blinking fast, and I had filled up shortly after that cause I wasn't sure if something more woudl happen after the rapid blinky before you were out... Cause even then I still was only able to put 10.2 gallons in, so I still believe I could have gone more than the length of the original normal blinky.... but what you say supports the fast blink last longer.... hahah Did I confuse anyone yet.. Im just looking for confirmation. Ron
198K Miles
N9QGS is offline   Reply With Quote
Anybody run into any other members in your area? vodkalush NY / NJ/ CT / PA 23 10-20-2008 11:31 PM
Stewart's Gas? ceres NY / NJ/ CT / PA 0 11-08-2006 08:08 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
