Old 12-09-2006, 03:35 PM   #19
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Originally Posted by dngz View Post
trying to make my own kit. i got like 100ft of #6 stranded wire with a nice thick rubber insulation. i think it's actually #6 welding wire or sumthing. I've got my heat shrink and my tie wraps as well but what for the terminals (stake on??) you use to crimp onto the end of the wire, i cant find anything that will fit #6 AWG. and for the circular plate, what kinda metal is that? aluminum?? will steel work?? like a cover plate for a electrical box?
6awg terminals are extremely hard to find you will have to buy 4awg terminals instead because a pack of 10 6awg terminals at UAP/Napa will cost you $18-$25
Chances are you will have to buy then from a welding supply company or electrical supply company.
8awg terminals are too small
Steel will work for a plate but will rust and corrode quickly with the moisture under the hood. It will need to be zink plated or galvenized steel. Copper or aluminum will work much better
Like I said before in one of my other posts at $21 shipped for a kit, I'm not making $$$ on these things really when you factor in the costs of all the materials to make them.
Aluminum, terminals, wire, shrink wrap (if used), all hardware, zip ties. not to mention the time it takes to make one and the shipping costs.
07WYarisRS is offline
Old 12-09-2006, 03:45 PM   #20
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Originally Posted by Wayside View Post
Got my kit the other day.
Everything looks nice, it was even packaged well!
For $21 it's not even worth trying to one off a kit for your self.
07WYarisRS, great product.
Thanks,
Wayside
Thank you
Glad to hear you are happy... if you have any problems or questions let me know.
Old 12-09-2006, 03:47 PM   #21
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
I have a battery mount grounding kit available
Made from 8 awg high quality power/ground cable, with gold ring terminals. Wires are transparent black and are complete/made to fit. The gold ring terminals are made by Monster.
Kit comes with everything needed to install the kit including the ground plate and mounting hardware, bolts to attach wires to ground points etc.
$21 each to US or Canada, shipping is included.
Battery mount kit
Old 12-12-2006, 09:47 PM   #22
skc
skc's Avatar
Drives: White5drRS
finally got my ground kit today.
i'm going to install it tomorrow.
Thx 07WYarisRS
skc is offline
Old 03-15-2007, 03:01 PM   #23
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Does it matter if u get both? or just 1?
-- Blen
Blenjar is offline
Old 03-18-2007, 09:48 PM   #24
Blenjar
Blenjar's Avatar
-- Blen
Blenjar is offline
Old 03-18-2007, 09:54 PM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
What are you talkin about Blen?
Black Yaris is offline
Old 03-18-2007, 09:56 PM   #26
Blenjar
Blenjar's Avatar
Installing both:
battery mount ground plate kit
firewall mount ground plate kit
-- Blen
Blenjar is offline
Old 05-02-2007, 12:04 AM   #27
d4w1
Drives: Yaris Hatchback
What I recommend, is that anyplace where a grounding point is attached. Is to make sure the bonding point has no type of insulation between the surface area where the ground is to be connected. To do this correctly, 1st, remove any paint and corrosion at the hole of attachment. Burnish the area with a small high speed round wire brush. The brush center guide pin should be the same diameter of the hole. The brush itself should only remove paint around the area where the bolt head or nut and terminal lead makes contact with the metal surface. For the best results these small wire brushes can be attached to any drill, air or electric. 2nd, Clean and treat the point where the bond is to be made. 3rd, Attach the ground lead with the proper size hardware. 4th, Test your bond with a mulitmeter, you should have very little ohm resistance reading on your meter. 5th, Touch up any bare metal surface with paint.
d4w1 is offline
Old 05-05-2007, 01:20 AM   #28
joey1320
joey1320's Avatar
Drives: Yaris LB
-- Blen
theres no reason to need both. one is more than enough. nice kits by the way
joey1320 is offline
Old 05-15-2007, 10:36 PM   #29
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Heya, I dont wanna start a new topic on this.........
Im thinking of gettin a voltage stabilizer aswell as some grouding wire........
is a voltage stabilizer worth gettin to help with the grounding wires?...bleh
hasher22 is offline
Old 05-29-2007, 10:25 PM   #30
Jerkratt
Jerkratt's Avatar
iw as wondering that to
Jerkratt is offline
Old 05-30-2007, 03:27 AM   #31
sort_o_sane
Yaris GSR LOL
sort_o_sane's Avatar
Drives: 07 Yaris Hatch
Since I don't know, What is the purpose of these grounding kits?
07 Yaris hatchback purchased in Dec '06. April 2015 and 103k miles, brakes finally needed changing, original battery finally died. I love this car.
sort_o_sane is offline
Old 05-30-2007, 06:55 AM   #32
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
They prevent premature hair loss.
Violin is offline
Old 05-30-2007, 03:11 PM   #33
sort_o_sane
Yaris GSR LOL
I could have used that a couple years ago.
Old 05-30-2007, 04:52 PM   #34
Jerkratt
Jerkratt's Avatar
lol
Jerkratt is offline
Old 06-02-2007, 01:12 PM   #35
Jerkratt
Jerkratt's Avatar
hey let me know when u gat a firewall mounting one up ill get it
"It hurts more when its wet"
Jerkratt is offline
Old 06-05-2007, 04:07 PM   #36
R0ME0
Drives: '00 Toyota Celica GTS Turbo
Do you offer different colors?
R0ME0 is offline
u.s. model body kits? delirium Cosmetic Modifications (Exterior/Interior) 27 09-07-2007 02:15 PM
Yaris Body Kits???? SamSam Cosmetic Modifications (Exterior/Interior) 23 01-15-2007 03:38 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
Any lip kits out yet? Spades Cosmetic Modifications (Exterior/Interior) 2 10-10-2006 03:28 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 01:18 PM
