Old 06-18-2010, 11:11 AM   #1
AND189
Drives: 2
everyone is an expert on here that is why we are here ha ha i was keen to master the clutchless shift just to see if i can do it
lutchless shifting is ok for straight cut gears not helical like the Yaris
well i can say i only did it once not a good sound ha ha, but if someone can shed some light on speed / rpm just to see if i can do it, it would be helpful mark293 ???
AND189 is offline   Reply With Quote
Old 06-18-2010, 12:34 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You got it!
Old 06-18-2010, 01:40 PM   #3
maybe try microimageonline.com forums...
stick around here too, not all the people are pretards
Old 06-18-2010, 08:40 PM   #4
tomato
tomato's Avatar
Originally Posted by mark293 View Post
Does anyone routinely shift without using the clutch? I did this for years on my 5 speed F350, and as long as you are in the right rpm range the shifts are just as smooth as using the clutch. The Yaris seems tailor made for this type of driving if you use common sense.
No. I don't think the clutch would like it one bit. .02
Old 06-18-2010, 08:50 PM   #5
clutch wouldnt care....its not getting used....
mark293, im not sure people on this site have every heard about shifting without the clutch...
Old 06-18-2010, 08:52 PM   #6
ddongbap
I do it when I'm tired. I down shift w/o the clutch too. 'Cept one time, it made this HUGE clunk. Even huger than normal, and the car did a jolt slow. Idk what it was, but I ignored it.
Old 06-18-2010, 08:58 PM   #7
ddongbap
Btw, you guys rage too much. If hes doing it wrong, tell him so. But let him keep doing it wrong. Who cares?
Old 06-18-2010, 11:01 PM   #8
djct_watt
Drives: 2010 NCP91 5spd
A good skill to have, but it is abusing the transmission. I hurt my left leg badly in a motorcycle accident once, and had to drive myself to the hospital. . . I did it all on one leg. It was in the Yaris.
Use the right leg to engage the clutch and start moving without any gas (lucky there were no hills). Once first was going, it was easy. Clutchless shifting from there on out (and it's very easy). Any car can be shifted that way. . . but your shifts have to be perfect. Mess up once and it's a hard grind. IMO, it's not worth it since it's so easy to just press the clutch.
If I was that lazy, then I would have gotten an auto.
djct_watt is offline   Reply With Quote
Old 06-18-2010, 11:22 PM   #9
sickpuppy1
Drives: 2010 Yaris Sedan
Truckers do it all the time, but the dont have sychro's and they are designed for this type of shifting after leaving low gear, I've heard its not good on the synchronizers also, but I'm no tranny expert. Funny, heres a video for ya, its called rev matching.
http://www.youtube.com/watch?v=jLw0h...=youtu.be&a%29
Old 06-18-2010, 11:52 PM   #10
Yaris Hilton
Smile
Rev matching = double clutching. The idea is to make the two shafts spin at the same speed before they come together. You can do that during the time the transmission's in a "neutral" state between gears without the clutch, but unless you can control the throttle so the gears have zero load on them as you're disengaging and engaging them, you're going to stress them more. The clutch is there to be used. Clutchless shifting is something to do in an emergency.
Old 06-19-2010, 02:04 AM   #11
ddongbap
Its not the same thing though. They end up doing the same thing, but are done so in different ways.
Old 06-19-2010, 08:12 AM   #12
wrong
Old 06-19-2010, 08:17 AM   #13
ddongbap
wrong
RONG.
Old 06-19-2010, 08:40 AM   #14
Originally Posted by ddongbap View Post
RONG.
i rev match w/o double clutching daily. double clutching is for trannies w/o synchro's.
Old 06-19-2010, 09:13 PM   #15
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
after all the drama in this thread, and watching that video on how to shift without using the clutch, I decided to try it. It worked surprisingly well... no grinding, no loud noises, just a slight bump when shifting. I cannot vouch for it's long term reliability, but it seems like a handy skill if you ever need it (hurt leg, clutch problems etc.) Sayuki handled it like a champ.
Old 06-21-2010, 02:20 PM   #16
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
i tried it too and it works without any problem what so ever.
a good thing to know for sure.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 06-19-2010, 01:45 AM   #17
Yar Is Word
Drives: Yaris 5 door liftback
Anyone remember "Clutch Cargo"?
Old 06-19-2010, 07:03 AM   #18
Yaris Hilton
Smile
I do!
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
