Thread Tools | Display Modes |
#19 | |
![]() Drives: 06 toyota yaris Join Date: Jun 2010
I TOOK OFF THE PLUG WITH THE BLACK AND WHITE WIRE WHERE YOU SHOWED IN THE PICTURE, AND SOMEBODY HAD DONE SOMETHING BEFORE, (CAR WAS BOUGHT USED), THEY PUT THE WIRES BENDED INTO THE PLUG TO MAKE CONTACT.... SO I TOOK EVERYTHING APART OF WHAT WAS DONE BEFORE, AND WITH A PLIER I TIED UP THE CONTACTS AND SQUEEZED IT DOWN AND LEFT EVERYTHING HOW ITS SUPPOSED TO GO, SO I TURNED THE YARIS ON AND EVERYTHING IS WORKING PERFECTLY WELL, THANKS SO MUCH! I'M GONNA DRIVE IT AND IF ANYTHING ELSE POPS UP I'LL WRITE IT HERE, HOPEFULLY NOT!!!!!!
#20 |
I think this guy is a toyota employee, he knows to much. KUDOS CT, and thanks again. Holla at me.
#21 |
Is it really that far to reach?
#22 |
so far so good drove 40 mins., and around NO PROBLEM!!!!!!!!!
#23 |
![]() ![]() Drives: 2007 4dr Sedan Silver Streak Join Date: May 2010
I'm pretty sure Toystory was yelling with excitement.
#24 |
oh yes I saved some $$ and I learned something
#25 |
Drives: toyota yaris 2007 Join Date: Jul 2010
need help also
Fews days a go i turned my car on and all that hapened
im having the same kind problem with my yaris 2007 Power steering is not working P/S light is on Check engine light is on A/C doesnt work the speedometer doesnt work I did a computer ckeck and a got the dtc P0500 Or fault speed sensor I cant imagine how just a speed sensor can be doing all that |
#26 | |
#27 |
Drives: yaris Join Date: Sep 2011
i have a some sort of a similar problem.. i have a yaris sedan 2006.. i can start the car without any problem but sometimes the dash board starts blinking its very hard to see though but when you carefully look at it you can see that it blinking and then the steering weel gets hard to turn..
i'm wondering whats the problem is this problem starts when i on the radio.. its kenwood.. i used my car without using my radio for quite some time the problem didnt come.. but recently someone had on the radio on its stand by and the problem came yesterday again.. but when i off and start the car it becomes normal again.. |
#28 | |
![]() Drives: Sedan Join Date: Feb 2009
#29 |
![]() Drives: 2007 yaris Join Date: Feb 2012
My wife's 07 hatchback is having similar issues.
Intermittently her charging system or airbag warning light will come on, she says the headlights sometimes dim when driving at night (and sometimes work fine), and says her heater doesn't seem to work as well as it used to. No mention of problems with power steering, radio, etc. I checked the A27 connector CTScott mentioned, hers appears a bit different, but couldn't see any problems there. Anyone have any other suggestions? |
#30 | |
#31 |
I checked the battery with a digital battery analyser at work, said it was good. Over 575 CCA, battery was putting out 12.3v w/ the engine off, at around 3k rpm it was slightly above 16v (high, I know, but wouldn't cause problems w/ dim lights, would it?)
Battery cables/terminals are clean and fuses are all good, ODB II reader returned no codes. The car was in to the dealer for servicing earlier and they said the alternator was bad and needed to be replaced. (the symptoms didn't seems to correlate to their solution in my head, anyway. I'm an electronics tech in the military, but in no means an expert at vehicle electrical systems) |
#32 |
16 volts is quite high. I think the voltage regulator within the alternator is bad.
#33 |
![]() Drives: yairs blue 2007 automatic 1.3 Join Date: Apr 2007
I would recommend checking the electrical board. couple of years ago i removed my ac fan to clean it and later that night my abs light turned on and some other stuff happened like the cabin light will turn on while braking ... etc. I took it to the service center i deal with and they have told me when i reconnected the fan i did it wrong which melted something and that was the cause of my trouble. I can not remember the issue exactly because it was long ago. I hope this could help.
#34 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
When I changed out my main ruse shown in CTscotts picture where the white wire and black wire were it was totally corroded....since I cleaned it and put some dielectric grese on them it is better than ever.I also had to change the main fuse out since I blew half of it.Car puts out more V now than when it was new...stays steady all day long with my amp on and everything at 14v before it was 12.9v.
#35 | |
![]() Drives: 2008 Black Yaris sedan Join Date: Dec 2012
THIS
I changed the pump, put everything back together, it started up nice n quiet now finally but: Basically the only electrical devices that come on are the headlights. No tails, running lights, radio, heat n a/c, tire pressure light and P/S light are on. The battery light is NOT on so it is charging. Yes, I removed the alernator to do the job, of course, and NO I did not drop it or anything silly like that. This is the first time I I have ever had to work on this car. If it makes a difference, I had to do this job after the water pump pully becoming so wobby it must have siezed for a decond and snapped the belt off at 75MPH. Thanks for the help, anyone! |
#36 | |
I am thinking that you did not pull the battery connectors when removing the alternator? If that is the case you likely shorted the high current wire from the alternator to the battery popping one of the large fusible links that is molded into the positive battery terminal assembly.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| solar trickle charger and alternator | wingdood | Fuel Economy Forum | 33 | 10-12-2009 04:02 PM |
