Old 07-20-2010, 07:28 PM   #19
centrysis
centrysis's Avatar
Drives: '08 Yaris LB
Originally Posted by R2D2 View Post
I run mine at 60 psi as well. Might be a tad more road noise but the car rolls freely and handles great.
whats the max pressure on your tire.i've always ran a higher tire pressure but never over the max.i heard its not good.
centrysis is offline   Reply With Quote
Old 07-20-2010, 07:50 PM   #20
STC
"LibertyRides!"
STC's Avatar
42 psi Summer and Winter...
Longevity, wear, and lower tire resistance!
Cheers!
~ Mark ~
Old 07-20-2010, 08:00 PM   #21
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
40 psi on all 4, pretty much all the time.
goliath1812 is offline   Reply With Quote
Old 07-20-2010, 08:50 PM   #22
bronsin
bronsin's Avatar
How many psi does it take to make a tire explode? I dont mean running it so it heats up and goes bang. I mean blowing it up like a balloon and POW!
Old 07-20-2010, 09:33 PM   #23
BailOut
Steals terrorist's lunch
BailOut's Avatar
It would take more pressure tan any pump I know of can deliver. Think about when your tire hits a pothole, or even better a pavement drop. The g-force is enough to increase the PSI exponentially and rapidly, but tire blowouts are rare.
- Brian
Share the Road
Old 07-20-2010, 10:51 PM   #24
djct_watt
Drives: 2010 NCP91 5spd
In general, this is true. Over-inflation increases your odds of a blowout when encountering rough terrain or a pothole. But an under-inflated tire is just as bad if not worse.
However, if you have damage to your tires, especially to the sidewall in the form of heavy curb damage, your tires will be significantly weaker, leaving the possibility of pop while pumping.
djct_watt is offline   Reply With Quote
Old 07-21-2010, 12:22 PM   #25
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Some people have probably seen this link before. It's an article about officers using tire pressures rated for max sidewell.
http://www.officer.com/web/online/Editorial-and-Features/Driving-Under-Pressure/19$27281
KrazyDawg is offline   Reply With Quote
Old 07-21-2010, 08:14 PM   #26
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
41psi. . .
. . . because of prolonged speeds over 130kph, mileage, and tire longevity (I always wear out the outsides of the tire first and over-inflation gives we even wear).
Over inflating does not give you even wear.
frog13 is offline   Reply With Quote
Old 07-21-2010, 08:16 PM   #27
frog13
Tw200--excellent!
Expo what?
Old 07-21-2010, 08:19 PM   #28
frog13
Tw200--excellent!
I run 60 PSI year round for both lower rolling resistance and much stiffer performance in the switchbacks in the mountains here.
Folks on this forum go ape shit every time I bring this up so be prepared for a thread derailment, but the only things I'll say are that I've never had a problem with this, it brought greater longevity to my tires, and I've even avoided becoming the 4th car in a 3 car accident thanks to my preparedness and alertness as well as the car's agile handling, even at 60 PSI. I even had a big puncture from a gnarly piece of metal I picked up and it didn't act any differently than blowing a tire at 35 PSI.
It just works, so get over it.
Old 07-21-2010, 09:43 PM   #29
djct_watt
Yeah, I agree with everything the article says. But it does not mention damaged tires. If a tire is already damaged, high PSI will stress those damage points, but you shouldn't be driving around on a damaged on sidewall anyway. But hey, I could be wrong as it is just based on my experience.
Old 07-21-2010, 09:47 PM   #30
djct_watt
Well, if you are heavy in your cornering, you will get heavy sidewall deflection (especially in a 60 series tire), thus wearing out the corners faster. Over-inflation minimizes this and CAN (in some instances) result in more even tire wear.
Old 07-21-2010, 11:49 PM   #31
Hershey
35 > 36 p.s.i.. Tried higher and it was choppier and felt those lousy roads / streets more and hear more rattles spring up . Few years ago we test drove a new '06 XB and it road like a brick on wheels . Could of used a styrofoam donut . Went back again to check tire pressure of the same XB and they were at 40+ p.s.i.. Let air out of each tire to about 35 p.s.i. and road much better . Ahhhhh relief . All in preference .
Old 07-23-2010, 02:04 PM   #32
1stToyota
1stToyota's Avatar
Their tires are most likely V, W, Y or Z rated, because they're concerned about high speeds, not long coasting.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 07-23-2010, 03:27 PM   #33
djct_watt
^ back in 2002 I used to buy used CHP tires from the CHP training facility in Sacramento. They ran 205/65/R15 V rated pirelli's. It was awesome because they still had half their life on them and ran leas than a 1/4 of the price.
Old 07-23-2010, 03:42 PM   #34
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
40 PSI at first to save a buck on gas, but I'll lower it to 38 or 36 when I notice the center section of the tread wearing down a little faster than the rest.
Old 07-24-2010, 12:50 AM   #35
Thai_Dang
Thai_Dang's Avatar
Drives: 2010 Yaris 5-Door LB AT MM
i bought mines new, and it came from the dealership pumped to 44 psi for the 15''. i didn't even know they can be pumped up to 60.
Thai_Dang is offline   Reply With Quote
Old 07-24-2010, 03:58 AM   #36
fluke_boy
Drives: 2010 Yaris 3 dr hb
When I first got mine from the dealer I noticed the low tire pressure light was on. I pulled over and scanned the owners manual and found out what the low tire pressure light meant as I had no idea at first. Pumped it up to 32 and it has stayed that way ever since. I guess I'll try 35 - 36 for the 15" when I next gas up.
fluke_boy is offline   Reply With Quote
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 11:34 AM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 02:20 AM
