Old 11-18-2006, 04:32 AM   #19
RogueYaris
Drives: 2015 Abs Red
I'm not sure why other's didn't go with this deal but I went ahead and bought the Oil for Life deal. Oil's just going to go up in price so I figure it's going to pay for itself in the long run.
Just a tip for those new to changing their own oil, stock up on supplies before hand like a couple drain plugs and drain plug seals so that you're not SOL if one of those happen to be bad.
RogueYaris is offline   Reply With Quote
Old 11-18-2006, 08:34 AM   #20
boris13
Drives: 2007 Yaris Liftback, 5-speed
It will be Red Line oil and K&N oil filters for me.
boris13 is offline   Reply With Quote
Old 11-18-2006, 09:36 AM   #21
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
http://home.mindspring.com/~cewhite3nc/id13.html
http://home.mindspring.com/~ed_white/id7.html
tomjasz is offline   Reply With Quote
Old 11-18-2006, 09:38 AM   #22
tomjasz
tomjasz's Avatar
And the Winner is…..
I was a little surprised by the results. With cost considered, the Motorcraft FL-820S was the highest rated filter, but not by much. Here are the results:
http://home.earthlink.net/~cewhite3nc/id3.html
Old 11-18-2006, 09:40 AM   #23
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
^^"Page Not Found"
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-18-2006, 09:42 AM   #24
tomjasz
tomjasz's Avatar
Originally Posted by gonzo452001
I have alway used toyota filters in my toyota's the main thing about them is the anti drain back valve keeps the oil from draining back to the oil pan over night makes the engine last longer. you can buy a case of 10 online for a lot less than most dealers
I buy them by the case from our sponsors and mine are marked Denso which is made in Japan. It seems for awhile they were purolator. Links I posted show Denso as a good quality filter manufacturer.
Old 11-18-2006, 08:11 PM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
I just use a good old champ filter.... from reading these filter rating links Champ (or Champion) is one of the better filters on the market for the price
Old 11-25-2006, 01:47 AM   #26
Dremor
Blankita Blankita
Drives: Toyota Yaris Hatchback 2006
Send a message via MSN to Dremor
I use Fram filter (The gray one) and Valvoline Max Life Oil.
Dremor is offline   Reply With Quote
Old 11-25-2006, 09:15 AM   #27
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
well i guess if you drive a $2 car use a $2 oil and filter
Old 11-25-2006, 10:28 AM   #28
Dremor
Blankita Blankita
I want the best for mt bb.
Old 11-25-2006, 01:00 PM   #29
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
mt bb ?
Old 11-28-2006, 06:34 PM   #30
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
on my last (and only) car, i always used quaker state oil & fram "double guard" filters.. never had any problems with the engine in 6 years, and it ran strong right to the junkyard. i figured i'd just continue as i've had good luck. but after reading all this, i'm now nervous to be using fram filters. the ones i get are about double the price of the "regular" filters. hmmmmm... unsure.
Old 11-29-2006, 10:08 AM   #31
Dremor
Blankita Blankita
mt bb ?
Sorry I mean: My Baby
Old 11-29-2006, 10:36 AM   #32
acrbill
Drives: Polar White Hatch
Here is some useful advice. If you choose to do your own oil change, make sure you keep all the receipts from the oil and filter purchase. If something happens to your engine Toyota will probably ask for all of your service records before they warranty the work.
On a side note, isn't there some sort of service light that needs to be reset? I thought I read that in the manual. Any idea how you reset that light?
Old 12-02-2006, 11:56 AM   #33
autophile
Drives: '07 HB Manual Yarrrrris
I think the Denso part number for the Yaris filter is 150-1012, or 150-1000 -- doesn't seem to be any difference between the two. They are available online for US$5.82 each.
Can anyone confirm that this is the right part number?
Thanks,
--Rob
Yarrrrrris!
autophile is offline   Reply With Quote
Old 12-14-2006, 02:17 PM   #34
autophile
Okay, well, the 150-1012 doesn't look like the filter on my car right now. 150-1012 seems to be a bit shorter and fatter. So much for using a 2005 Echo filter.
Yarrrrrris!
Old 12-14-2006, 02:43 PM   #35
Tamago
Tamago's Avatar
Drives: UZJ100
i would not use the fram filter if my life depended on it.
buy your toyota filters online like i do, from partznet.com
they're currently $21 for a six pack..
better price than a fram and way better filter!
Old 12-14-2006, 03:10 PM   #36
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Talking about the Mobil 1, usually there could be found two Mobil 1 type of oil. Mobil 1 and Mobil 1 Extended Performance. Only the last one is meant for extended oil intervals
here's a link about it: http://www.mobil1.com/USA-English/Mo...Oils/Oils.aspx
hystria is offline   Reply With Quote
Yaris stereo change PDFs YarisBueller DIY / Maintenance / Service 13 10-15-2022 04:52 AM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 09:32 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
