#1 |
...or Vegas for short
Drives: 2010 Toyota Yaris 3door LB Join Date: Jul 2010
Voiding a warranty
anyone know what performance modifications will void a dealerships warranty? im planning to add headers, exhaust, and an intake to the yaris soon but i dont want to void anything.. help?
Drives: 07 sedan Join Date: Mar 2010
*waits for some uninformed person to start spouting off about the magnusson moss act.
But in the mean time, yes those can all void warranties. BUT, done properly most dealerships will let them slide. |
#3 |
ok i guess ill just have to ask the dealership if theyll let them slide
#4 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Best thing to do is keep the oem stuff around just in case and u can swap parts if it comes down to that.
Dealer is going to have a hard time trying to prove anything with the oem parts on the car. |
#5 |
Thanks ill do that too
#6 |
![]() Drives: evo x gsr Join Date: Jul 2010
The MMWA is basically the answer, but if your doing your own work on your car your not really going to need the dealer to warranty anything except the tranny and engine in which case you might have your hands full. Best answer is always to save to stock parts and go back to stock if any problems do arise. You can always ask around and try to find a mod friendly dealer.
Speed Circuit UICP, CAI-BLOX velocity stack-Waste Gate mod 4 turns-TWM Short Shifter with 400gram knob-COBB AP, Turbo Inlet Hose-UR HFC, 4.5"intercooler, dual exit catback-Perrin Rear Swaybar-Enkei RPF1s 18x9.5 Black-HKS SSQV recirc-AMS downpipe, SS brake lines, LICP-Grimmspeed 3 port-boost gauge in ashtray-Rally Armour UR Mudflaps-Rexpeed CF HoodScoop, VG-Swift Springs- APR Front Splitter-AEM AFR Gauge |
#7 |
Put it this way, if you install a header and later down the road your O2 sensor failed they could deny you a warranty claim because the header could be the cause. But if you had a problem with the wipers, they aren't going to deny you warranty because of a header.
Catch where I'm going with this... |
#8 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
#9 |
#10 |
![]() ![]() Drives: Yaris 2010 Liftback Join Date: Feb 2010
does anyone know which aftermarket parts would void insurance? i've heard mixed things about this.
#11 | |
Only Happy When it Rains
Or if you installed a new suspension and it completely failed, any damage that happened because of the modified suspension would not be covered under warranty. And yes, both those examples are absurdly far fetched. What they cannot do is deny warranty coverage on the engine if you're car has aftermarket wheels and a spoiler. And it is always good to check around and see if there are dealers that are mod friendly, or sell and install mods themselves.
Colin Chapman disciple |
#12 |
#13 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Yeah, but don't forget the dealer has legal fees as well! Why do you think all big companies settle? Because it's cheaper than going to court, even if they are sure to win. That's the sad part...
5% Tint Rear | Micro Image LED Ignition Light Kit |
#14 |
I was actually asking a different question. It is related so I was wondering if anyone here would have info.
I'm not worried about my warranty. I'm worried about my auto insurance with Metlife. I've heard that if you are ever involved in a crash with aftermarket parts, your insurance could be voided, leaving you without coverage. How are people insuring their cars with aftermarket parts? |
#15 |
![]() Drives: 08 Yaris 5spd Sedan Join Date: Sep 2010
Most insurance companies, when you fill out their policies, will ask whether or not your car has custom parts/aftermarket modifications that are valued over a certain amount. Progressive, I believe, won't cover anything worth over $1,000.
If I'm wrong please correct me. |
#16 | ||
Most insurers will not cover the aftermarket parts at all, they have special really expensive insurance for that type of thing. So they will cover your car, but they will not replace aftermarket parts without special coverage. Quote:
#17 |
Yaris Noobie
I am an Independent Mechanical Inspector. I'm the guy an extended warranty company sends in to inspect your car if there's a claim from a repair shop. I can't speak about the factory warranty, but I can speak about extended warranties. If you read your extended warranty contract, there will be a clause in it stating something along the lines that if you modify the vehicle, they can deny coverage based on the modification. Example, if you install headers, intake, turbo, nitrous, etc., and have an engine or transmission failure, the company can deny coverage based on the modification. It you raise or lower the suspension, and have a suspension failure, or a trans or axle failure, the company can deny the claim. They cannot stop you from modifying your car, but they can deny coverage. I have seen manufacturers and dealers deny factory warranty coverage to a couple of heavily modified Mitsubishi's. One had a full cage, with racing seats, race type tires & wheels, and some mods to the turbo system. It was a street driven car with less than 12k on it. It had wiring issues, and the dealer, with the factory rep's blessing, told the owner, they would do no warranty work on his car. I was there for the first refusal of work. I have no idea what happened later.
Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist. Last edited by Dragracer; 09-22-2010 at 08:00 PM. Reason: Spelling! |
| quick warranty question | enobmort42 | DIY / Maintenance / Service | 10 | 08-25-2010 02:51 PM |
| Factory warranty + warranty extention | pip | General Yaris / Vitz Discussion | 12 | 07-25-2010 05:18 PM |
| Warranty Information for US Yaris Owners | AdeJong 03 | General Yaris / Vitz Discussion | 4 | 09-19-2009 10:14 PM |
| Aftermarket parts and Factory Warranty in Canada? | jonathanq | Canada | 3 | 07-11-2009 12:17 PM |
