#1 | |
![]() Drives: 08 Yaris Sedan AT Join Date: Jun 2010
The fuel spills on the side of the car, not under the car |
#2 | |
So, it really points to the pumps not being setup properly. I would try a completely different gas station than you've used and ideally one with super modern looking pumps. |
#3 |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
If the problem persisted before the warranty ended, you may still be eligible to have it serviced by the dealer. It's ultimately up to the dealer's discretion, but they have funding for people who "make a fuss." Make enough noise, and they make take care of it. You have to be a PITA to the dealer though. . . sometimes being nice works, but in my experience, people fear the whip more than they want the honey.
#4 |
could be related
http://www.toyotanation.com/forum/ar...p/t-57654.html |
#5 |
I tried today filling up with holding the nozzle at 45 degree angle. It helped. It was annoying to hold the handle while filling, but I will take that over spilling the gas on the side of my car.
Thank you for the help. |
#6 |
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
How did you fill up before? Were you using the gas cap to hold the filling nozzle open???
#7 | |
I used to just put the nozzle in as far as it goes (which is not very far) and push the handle and "put on" the little lever to keep the gas flowing on its own. |
#8 |
if you do it at 180 degrees, you won't have to hold it. That's what I used to do (because I was lazy).
#9 |
![]() ![]() Drives: 2007 4dr Sedan Silver Streak Join Date: May 2010
In Canada almost all gas stations have the autofill disabled, to get around this we wedge the fuel cap in under the lever to hold it on until it clicks off. Canuck may not be aware of the autofill capabilities of gas pumps.
#10 |
Wow. . . even in Thailand we have the auto-shutoff. . . what's all this fuuuusss really abooot?
#11 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
In some states in the US the auto-shutoff is disabled as well. Aimed at reducing spills where the feature doesn't work when the operator has walked away and left it unattended.
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Also, filling slowly will result in spilling. Jam the nozzle in, and run it full blast. I have only spilled once, and that was from slow filling.
#13 |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
I never top it off. I always wait for the first click and no more.
#14 |
![]() Drives: 2008 4 dr Yaris Join Date: Dec 2010
I dont have a check engine light, I dont have a leak, I've held it every angle possible. I dont top off, It is getting worse and probably spits out a cup or two. It actually projects out though and causes a terrible mess. If your hand is on the pump you get gas all over your hands. Its terrible
#15 |
![]() Drives: 2012 Yaris Join Date: Aug 2013
I realize this is an old thread, but my 2012 Yaris has the same problem. It doesn't matter how fast or slow I fill, or which gas station I use. Every time without a fail. I couldn't find a TSB for it. I was just wondering if the OP ever figured it out.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Had problems filling the gas / petrol tank? | fidgell | General Yaris / Vitz Discussion | 6 | 08-27-2010 03:47 PM |
| Filling up using spare gas tank. | Yarimoto | Fuel Economy Forum | 5 | 08-19-2009 04:29 PM |
| Don't overfill your gas tank! | kimona | General Yaris / Vitz Discussion | 19 | 07-17-2007 01:15 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
