Old 09-10-2010, 05:26 PM   #19
sleey0
Drives: 2008 Yaris LB
Looks like a show car that would decimate all at the track!
He said it isn't his de, but if that was mine It'd drive it everywhere.
sleey0 is offline   Reply With Quote
Old 09-10-2010, 08:44 PM   #20
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Can't wait to see track times after it's tuned up!
Old 09-11-2010, 12:57 AM   #21
xbgod
Drives: "Burning It Down GTX2860RS XB"
Orginally was just to make the fastest first gen Xb on a 1.5l motor. Now it's become more of a well built street car that can handle well.
I do alot of corporate shows for Scion so I think the more extreme it is the better response I will get. Plus it's kinda nice knowing you got the best of everything (in my opinion) under the hood and under the body inside and out.
The car is just for fun no real worries about what to do with it.
XBG
xbgod is offline   Reply With Quote
Old 09-11-2010, 01:07 AM   #22
sleey0
No worries?
For the price of and Audi S4, stacked, or a fully-built EVO, I would think I would "worry" about it quite a bit. l2ms
Sweet ride, bro.
Old 09-11-2010, 03:56 AM   #23
xbgod
I cant look at it that way, this has been done over a 4 year time span so the money has been put out in pieces at a time. and besides someone's gotta do it.
This has just been a journey to see how well built and nice it could be done. Anything worth doing is worth doing well.
Yes it's been expensive but I've been fortunate to be able to do this. I've also made alot of head way for others by doing this. So I think it's been well worth it.
XBG
Old 09-11-2010, 04:05 AM   #24
xbgod
Heres a pic of my dash....This is what it did look like, the new dash is underway. New tricks up my sleve...
Old 09-11-2010, 10:57 AM   #25
xbgod
PETERPOOP.....was meaning to tell you, Your Yaris nicely done. Very clean and it sits well.
Old 09-11-2010, 11:51 AM   #26
xbgod
Here are some pics of the full stand-alone unit in my car. This is a Microtech set-up with Nology hot wires and Bosch Coil packs.
Old 09-11-2010, 01:03 PM   #27
PETERPOOP
PETERPOOP's Avatar
Oh hey thanks! hehe.
Old 09-12-2010, 01:23 PM   #28
xbgod
Remember people, just because you have nice parts and things that shine dosen't make it just a show car. It just means you have the ability to have those expensive parts as well as make it perform.
Here is a pic of a close-up of my motor showing the direct port Nitrous set up that I had welded in on the Weapon-R intake manifold. The blue tape is where the nitous feeds are going. Also all those interested in a clean nitrous set up, I've included a pic of the billet rail I'm using that holds all 3 noids. Makes for a clean install.
Old 09-12-2010, 08:26 PM   #29
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
What made you go with Microtech? There are certainly better aftermarket management systems produced in Australia.
rob323 is offline   Reply With Quote
Old 09-13-2010, 12:53 AM   #30
xbgod
Been using microtech for years. Orginally because it was my only real option 4 years ago. I tried the Greddy stuff back then and it sucked so bad I threw it in the garbage. Microtech is simple, it's in your face raw racing power, it's like MSD on steroids. no MAF sensor to worry about or other sensors to worry about. Microtech sees all my other sensors without issues and tunning is breeze. Also when seeking a tunner you need to also see what they tune with the best and that their not just guessing with your shit. I chose this system based on having a tunner that is certified in this system and a system that was reliable.
Yes there are newer and better systems out now and once I'm done if I'm not totally happy I will be going to Motec. This sysem will run me about 9,000.00 installed and tunned with all the features I would need. Motec is alacarte so every option cost you. I have the money to do this change but I want to see how things go this way first, before I spend another 9G.
XBG
Old 09-13-2010, 01:03 AM   #31
rob323
Will Microtech interface with a knock sensor yet?
Old 09-13-2010, 06:34 AM   #32
xbgod
Good question and I'll be honest I don't even know if I have mine hooked up that way or not. I've gotten so good at listening for detonation that I back off when tunning. Not to mention I use Racing fuel when I'm tunning. Thats the other beauty of not having this as my daily driver is I can run race fuel and not worry about the expense.
I know some things have changed for the Microtech set-up so I'll find out for you about the knock sensor.
Also keep in mind I may not be running the VVTI like most do. I'm going to use such a wild cam that I will more than likely not run VVTI.
I've been running my set-up like VVT instead of a VVTI application as it stands right now. Remember I'm not using a MAF sensor. My set-up is race oriented. I don't care about fuel economy and I make up for the torque with my cams. These are two things that are usually related towards the VVTI which is responsable for both.
XBG
Old 09-13-2010, 05:44 PM   #33
Tamago
Tamago's Avatar
Drives: UZJ100
interesting points of view in this thread, and lots of stock-photos of parts........
Old 09-14-2010, 08:52 AM   #34
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
XBG
I don't know Microtech but I am sure Haltech is better. It has about the same capabilities of a Motec engine managment. Currently Installed on my yaris although still needs tuning. Will post a dyno sheet next week probably.
Old 09-15-2010, 08:25 AM   #35
xbgod
Haltech is for sure better than Microtech. My issue is I've been using Microtech for 4 years and have built more of a race motor and only using VVT. If at some point I need to change it will be for Motec.
There seems to be a certain ass-clown who has a car with 2 dicks hanging out the ass-end for tale pipes. Who seems to think because orginal photos of parts were published that I must not have them. Little hard to take pics of parts when your in Iraq. Any question about how much money I have to spend on parts call Paul at Dezod, whom I'm real good friends with...He'll tell you my pockets have almost no bottom when it comes to parts. Like the pic of the axels that I bought from him.
You my friend have a big mouth and most people here can't stand you, which reflects all the private PM's I get from guys telling me so. do your self a favor go join the MR2 convention.
I'm more than likely going to take a heat round from a MOD for this but I have too many people telling me that this shit has to end.
XBG
Old 09-15-2010, 09:48 AM   #36
Parmas
Parmas's Avatar
I agree with you on the parts. Quality cannot be an option on cars and behind that is your insurance for your motors life and yours included.
Keep up the good work and don't forget to leave some cash for the kids.
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Chevy Aveo RS: Turbo + good looks = build it! Thirty-Nine Off-topic / Other Cars / Everything else Discussions 22 01-12-2010 12:36 PM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
