Old 09-14-2010, 01:31 AM   #19
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
So, in CTScott's picture above, as long as the wires from 3 is connected to 13 with a splice, the fog lights will come on with the park lights?
chrisj is offline   Reply With Quote
Old 09-14-2010, 02:06 AM   #20
sleey0
Drives: 2008 Yaris LB
Yep.
Just make sure to wire the rest the oem way and you are set.
sleey0 is offline   Reply With Quote
Old 09-14-2010, 08:39 AM   #21
Correct. And Ray's (1NZ's) pigtail pictured above, lets you do the mod without cutting into the OEM wires. With his you pop the pins, connect them to his one pin connectors, and the splice happens within his harness.
Old 09-14-2010, 09:20 AM   #22
chrisj
chrisj's Avatar
I appreciate the help. I'm not installing the fog lights myself. A custom shop is doing it, and although they say they've done these before, I printed out all these instructions to make sure the lights get wired up to the parks. I'm getting the fogs installed at the same time I get 3 little dings fixed.
Although the separate switch is nice, it would never work for me. I'd be calling for a jump all the time (leaving them on).
Old 09-14-2010, 09:41 AM   #23
In that case, check out my headlights off with ignition DIY. My Subaru had auto off headlights, and I got so used to it that I kept leaving my Yaris' lights on:
http://www.yarisworld.com/forums/sho...diy+headlights
Old 02-12-2011, 04:38 PM   #24
henrystyle
Drives: 2010 5 door yaris
If you got the latest kit from Garm
return it and ask him for the non modified kit
it will wire into your park lights a lot easier
than the new kit will .
As the new Modified MI Kits are a factory setup
and plug and play .
New to the site. I want some foglights installed on my 2010 5 door yaris in the same manner.
Question. Who is Garm and where can I buy this latest kit your talking about?
Is this it?
http://shop.microimageonline.com/Fog...-foglights.htm
henrystyle is offline   Reply With Quote
Old 02-12-2011, 05:46 PM   #25
MadMax
MadMax's Avatar
Is this it?
Yep, that's Garm and probably one of the best vendors on this site!
Old 02-12-2011, 09:36 PM   #26
swidd
Drives: Yaris HB
By "fog lights on with the parking light switch", that means they are on when the stalk is in the middle position, off when in off position, and off in the running light position? Or do the fog lights also go on with normal running lights on (stalk in "night"/running lights position)?
I'm on the fence about fog lights pending a proper way to get a switch solution for them.
Old 02-19-2011, 08:13 AM   #27
henrystyle
Tagging along
Old 02-19-2011, 08:13 PM   #28
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
I'm gonna order that kit.
So all I do to make them come on with the parking lights is connect the yellow wire to the white wire? Can I just use a small piece of wire with 2 wire taps to connect them?
bB2NER is offline   Reply With Quote
Old 03-03-2011, 12:42 AM   #29
henrystyle
Do the park light mod instructions come with the kit as well as the jumpers?
Just ordered mine.
Old 03-09-2011, 12:28 PM   #30
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
hi is there a h.i.d fog lights i want to match the light color blue with my h.i.d head lights ? please help also looking for that wire harnes adapter to run on stock light controll no need for switch in console help help
pennyracer is offline   Reply With Quote
Old 03-09-2011, 08:27 PM   #31
pennyracer
boydstir
pennyracer's Avatar
if a set is out there for sale does anyone know ware to get it ? please advise
Old 03-10-2011, 02:05 AM   #32
what color are your headlight HID's?
blue is 10000k to 12000k usually. could get a set of H11 to match.
Old 03-10-2011, 11:13 AM   #33
pennyracer
boydstir
pennyracer's Avatar
yes they have a blue tint to them do you have them for sale and i want to run them off the factory light controll stack dont want to run any more wires thru the firewall right now thanks for any help you can give me
Old 03-10-2011, 11:26 AM   #34
pennyracer
boydstir
pennyracer's Avatar
just found out they are 8000k does this help my h.i.d. power paks are up in the fender well back in ware the from window piller post come over the top of firewall i dont like looking at extra non factory parts if possible
Old 03-10-2011, 11:30 AM   #35
pennyracer
boydstir
pennyracer's Avatar
had to ask the guy i purchased the lights from got the info ready to buy matching fogs
Old 03-10-2011, 11:41 AM   #36
You need a foglight kit + an HID kit, right?
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 05:49 AM
2009 HB fog light installation rbell DIY / Maintenance / Service 3 06-17-2009 10:16 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
