#1 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Great, thanks Scott - going to attempt this when I have time
Not quite a noob
Oh, one more thing: could I ground it to the power mirror wires? That way I only have to run one wire through my door to the electrical panel right?
#3 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I'm putting this mod on the to-do list, behind the supercharger, gauges, amp, HID conversion, wiring the fogs, and mounts to move the passenger seat further back.
#4 |
Possibly. You would have to check to see how good the continuity to ground is for the door.
#5 |
Not quite a noob
Bump, Scott?
#6 |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Fan speed to 3 or 4, recirc air, direction selector all the way to the lower right (windshield), heat set to full blast, dash vents open and pointed to the triangle windows... and the mirrors clear up just as fast as any of the cars with heated mirrors I've had before (Golf III, Scirocco II, BMW 2 series).
Enough ice that neither this, nor some de-icer spray can deal with, heated mirrors are a lost cause as well, because they're very low powered. |
#7 | |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Shit.... for that matter if you blast the rear window long enough with the air from the vents above the radio you don't need it as well. |
#8 | |
#9 |
#10 | |
After the snow was half gone from the heated mirror I shut it down as my neighbors may start to get a little concerned about me watching me video taping my mirrors in 14 degree weather.
#11 |
Awesome! Congrats!
#12 | |
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
| Heated Side View Mirrors | goku87 | DIY / Maintenance / Service | 27 | 01-26-2016 05:23 AM |
| Unlinking heated side mirrors / rear defrost | Alezius | DIY / Maintenance / Service | 9 | 11-03-2010 01:29 PM |
| heated mirrors on 09 model? | DOMAV | General Yaris / Vitz Discussion | 34 | 10-27-2009 04:13 AM |
| Replacing manual mirrors with powered plz help | MikeB | DIY / Maintenance / Service | 0 | 05-27-2009 09:55 PM |
| Will '09 Heated mirrors fit on an '08? | goku87 | DIY / Maintenance / Service | 1 | 11-17-2008 05:39 PM |
