Old 09-27-2010, 04:28 PM   #19
swidd
Drives: Yaris HB
Here's some pictures...
Old 09-27-2010, 08:53 PM   #20
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Garm center colsole leather match so well with your leather seats!! :) Thumb up!!
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 09-28-2010, 05:47 AM   #21
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
I just ordered the MI armrest with black stitching. Man, we miss having an armrest in the car!
chrisj is offline   Reply With Quote
Old 09-28-2010, 12:22 PM   #22
swidd
Drives: Yaris HB
Awesome, yes, however it introduces a new annoying sound, as the passenger seat gently vibrates during driving, it rubs against the leather armrest. Being the rattle-psycho that I am... It drove me nuts.
If you look closely, you can see I put a patch of nylon on the sides of the armrest, in matching color, to smooth the contact point between the Clazzios and the MI armrest. I found the patch in the sewing and home crafts section of walmart for about $2... 8x8" self-stick nylon patch intended to fix tents, backpacks etc.
Old 09-28-2010, 12:28 PM   #23
^ that does look great, and props to you for being able to fix the small problem you had!
Old 10-09-2010, 08:55 PM   #24
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
Any chance of seeing the back of the armrest where it fastens to the centre console?
PumpkinSteve is offline   Reply With Quote
Old 03-11-2013, 09:00 PM   #25
goose1uponu
goose1uponu's Avatar
Drives: 2009 Sedan
http://cgi.ebay.com.sg/Toyota-YARIS-...item19b5348ca7
Anyone here using it? I am seriously looking for a good armrest.
Personally i love the look of the JDM console but they are really seem too low to use it as armrest. As for the OEM USDM armrest will be nice to use but i just hate the rear cup holder extended further out than the stock cup holder position. & they are black ABS plastis unlike our dark gray plastis...
Smame problem here, armrest is too low. Is there something I can buy to get it higher?
goose1uponu is offline   Reply With Quote
Old 03-13-2013, 05:29 AM   #26
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I bought an armrest about a month ago and I love it! I'm 5'10" 200lbs and it is perfect. I got it from
http://www.ebay.com/itm/390446315217...84.m1497.l2649
The first armrest I received wasn't lined up correctly; however, I contacted the seller and he sent a new one in a hurry. The screw that came with it did not fit because I was unable to get the washer off. I went to home depot to purchase a new screw and installed it. I like the compartment under the plastic piece - gives me more of a piece of mind ^^"
MyzticZ3r0 is offline   Reply With Quote
My opinion: The YARIS needs a standard center armrest! YellowJolt General Yaris / Vitz Discussion 41 07-20-2009 02:03 PM
HELP: JDM Armrest Console Box part number GabL Cosmetic Modifications (Exterior/Interior) 7 10-24-2006 11:12 PM
