Old 10-14-2010, 07:13 AM   #1
SimTronik
Machinist
Drives: Yaris sedan 2010
Just got some brand new TOYO Observe G02 Plus. Hope their good.
Winter is at the door here.
SimTronik is offline   Reply With Quote
Old 10-14-2010, 09:11 AM   #2
MUSKOKA800
MUSKOKA800's Avatar
My Goodyear Ice radials are nearly done. They have plenty of tread depth but the rubber is stiffening up and not as grippy last winter as in the past. They say five years max. for winter rubber before it loses it's grip.
I'll switch to Michelin XIce when I take the plunge. They're a great all-round winter tire but should last 30% longer (mileage wise) than other winter tires. I'll run 175/70/14 on my 14" steelies to match the OEM 23.7" diameter of the stock 15" OEM rubber.
Old 10-14-2010, 10:46 PM   #3
Lil Abner
Drives: 2009 3dr LB Manual
I got some Pirelli Winter Carving snow tires, 175/65R-14, and a set of 14" steelies. I haven't used them yet, but winter is right around the corner!
Old 10-15-2010, 07:15 AM   #4
SimTronik
Machinist
Yup. Getting colder.
Any 2010 top 10 best winter tires?
Old 10-15-2010, 04:41 PM   #5
jstantherprsn
Drives: 01 Toyota Echo
There are wheels out there with diamond fragments and dust embedded into the tire. They are popular in iceland, you have to put like 5k on them before you wear off the outer protective rubber to expose it. Almost looks like winter tire with salt and stuff embedded in it. I don't know if they are in the states yet.
jstantherprsn is offline   Reply With Quote
Old 10-15-2010, 04:52 PM   #6
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Michelin X-Ice Xi2-lov'em. Fantastic grip and stopping on snow and ice. They get a little spongy feeling in temps above 60 degrees, but that's to be expected. They are great winter tires. I considered the Toyo G2 Observe a year ago, but thought the technology was old-using ground up walnut shell in the rubber compound to get the grip. But I am curious to read owners results.
Old 10-18-2010, 11:14 AM   #7
henry33
Drives: yaris1.33
what weight index do you use ?
i have bought 88 T isn't this too much for yaris ? thanks
henry33 is offline   Reply With Quote
Old 10-20-2010, 06:37 PM   #8
docB
Drives: '09 Yaris Sedan
I had Fireatone Winterforce on a 1997 Crown Vic I had. They were narrower and taller than the regular size. Really fair price,awesome performance.
They are for sale. 205/75R-15, one on a rim, mounted & balanced. PM me if interested.
doc
docB is offline   Reply With Quote
Old 10-20-2010, 06:58 PM   #9
Lil Abner
The tires I got are listed as 86R tires (1168 lbs per tire). An 88 is listed as 1235 lbs per tire. I think your higher load just means it can take more load, but shouldn't be a problem on a Yaris. I found the info here:
http://www.tirerack.com/tires/tirete....jsp?techid=35
Hope that helps.
Old 10-22-2010, 05:06 PM   #10
henry33
Drives: yaris1.33
Hope that helps.
thanks you are right no big difference
hava talked to conti customers care
Old 10-21-2010, 12:47 PM   #11
johnny_vitz
Drives: 2005 Toyota Echo
I used Firestone winterforce the last 2 years on factory steelies - good tire for the price (cheap) Switching to 195 55 15 Michelin X Ice on 15" Heliums this year so we'll see how they are.
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 10-21-2010, 04:58 PM   #12
Kal-El
Kal-El's Avatar
Continental Extreme Winter Contacts.
Yes, all season tires are junk in the snow. All season = no season.
Those who have never ran snow/winter tires have no idea what they're missing.
When you do, you'll never run all-seasons again.
I haven't gotten stuck in anything with these. And I if you were to set up cones on snow, I'd be able to slalom through them at a good speed.
Old 10-22-2010, 05:04 PM   #13
henry33
Drives: yaris1.33
agree
Old 10-28-2010, 02:46 PM   #14
Astroman
Modded Moderator
Astroman's Avatar
I've got an appointment in 45m to get the Bridgestone Blizzak. I was looking for some used studded tires the past 2 winters on craigslist but can never find a pair the right size. Will be running 185/60R15 on OEM steelies. I was using the stock goodyear tires sipped and they were pretty good but alas they've worn down to be no good for winter, but fine for the rest of the year.
Old 10-28-2010, 03:07 PM   #15
Kal-El
Kal-El's Avatar
You're not just putting 2 winter tires on, are you? Unless you mean 2 studded, 2 regular snow?
Many people believe they only need snows on the drive wheels. Very dangerous! The demo videos I posted earlier in the thread demonstrates this danger. Basically, your car becomes bi-polar and each half of the car is going to do different things. In a FWD car with snows only in the front, your ass end is going to be everywhere other than planted.
Old 10-22-2010, 05:07 PM   #16
SimTronik
Machinist
They look great. I always have regrets when i choose tires lol There is so much. Hope i did a good choice with my Toyo G02 plus cuz yours seems really great.
Old 10-22-2010, 05:38 PM   #17
Kal-El
Kal-El's Avatar
Did a lot of research (Tire Rack .com is the most informative) and these Continentals always scored either #1 or #2 for overall performance in comparison tests. Blizzaks are the other top rated, but more expensive.
Old 10-22-2010, 05:45 PM   #18
henry33
Drives: yaris1.33
that is why I have bought continental
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Winter tires and wheels (new-be) rog_ski Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-24-2009 01:34 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
Winter Tires lily Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 10-14-2009 02:56 AM
Winter Tires? sketch182 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 10-23-2008 06:47 PM
