Old 10-22-2010, 11:39 PM   #19
Slick
Slick's Avatar
Drives: '09 3-Dr
Yeah, Brian and I have had several discussions as to the best way to wrap the pockets. In the end, he says he has tried but has a difficult time getting it to come out perfect. We discussed several methods, all of which are a pita, however I think he came up with a winner. So I will be the guinea pig on the pocket plan lol. The fall back plan is to paint it (insert preferred color here) and clear coat it so its shiny in the pocket and just wrap the CF down into the pocket over the edge a small bit.
That particular section is next on my wrapping list lol.
Old 10-22-2010, 11:48 PM   #20
Slick
Slick's Avatar
Drives: '09 3-Dr
Yeah, that is the general idea. However, the first piece for the pocket is the pita part lol. CF acts like no other fabric; its firm and yet at the same time the weave can easily come apart. You can't bend CF around more than a couple of sharp corners without consequences. The hard part is trying to get the CF in the hole without it fraying during placement or fraying while adding the resign. Usually you keep the weave straight using tape on the ends, then apply the resign, then cut off the extra. The resign keeps the weave in place once dry. However, with the pocket, there is no way for tape to be applied to keep the weave straight.
Feel free to PM me with any questions or thoughts :)
Old 10-23-2010, 12:37 PM   #21
Slick
Slick's Avatar
Drives: '09 3-Dr
Alright, here is another mini-update, I made another pass with the Ultra Cut and topped it with some Megs Deep Crystal Polish.
I applied the clear coat a little after this picture was taken and its in the shop now drying. So, hopefully it will look twice as shiny/reflective as it does now. I should be able to touch it sometime later this evening. I'll update tomorrow when I get the clear coat wet sanded :) Im so close to finishing this piece I can taste it :D
Old 10-23-2010, 12:39 PM   #22
2009BBPliftback
2009BBPliftback's Avatar
Amazing work. Love the finished product can't wait to see it installed!
2009BBPliftback is offline   Reply With Quote
Old 10-23-2010, 12:42 PM   #23
DandiDani
DandiDani's Avatar
that looks great!!!!
Old 10-23-2010, 01:15 PM   #24
YAR1S
YAR1S's Avatar
amazing, love how it matches your car's colour!
-Jen <3
Old 10-23-2010, 02:13 PM   #25
maxxman420
prop215.
maxxman420's Avatar
Drives: Toyota Yaris LB
Nicely done!
maxxman420 is offline   Reply With Quote
Old 10-23-2010, 09:00 PM   #26
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
I have used CF, Kevlar and fiberglass extensively while building an experimental aircraft (http://www.cozyaircraft.com/). Here are a few tips that I have picked up working with resin and glass.
Tip 1: First the fabric will almost always fray at the edges when cut. What we typically do is to wet out the fabric with resin about 1/4" to 1/2" past the edge of the material. Let the resin partially cure, the resin that I use takes a full 24 hours to cure and is semi cured at about 2 hours. Once it is partially cured take a sharp razor knife (utility knife) and you can trim the material nice and neatly without fraying. Knife trimming while it is partially cured will save you HOURS from sanding and cutting a fully cured piece.
Tip 2: None of the materials like to go around sharp corners without lifting off the surface and creating a bubble near the edge. To get around this I use plastic sheeting a thin sheet (about 3 mils) works well. After you wet out the fabric with resin lay the sheet on top of the fabric and then squeegee or stipple the sheet onto the wet fabric. The plastic will do two things, it removes the air from resin and when the resin cures you can pull the plastic off the surface with ease. It will leave the surface shiny and level.
Tip 3: If you don't know how to work with the fabric, it is less expensive to buy fiberglass and experiment with that, than to start with CF. You can buy what is known as a BID weave fiberglass that has very similar characteristics as the CF.
az_saguaro is offline   Reply With Quote
Old 10-23-2010, 09:38 PM   #27
Slick
Slick's Avatar
Drives: '09 3-Dr
Very informative, thank you. Although, CF in my opinion isn't really that hard to work with. If there is one thing I can say to new people such as myself and others is to not be afraid of it. So far I have had excellent success with my first attempt and look forward to the rest of the project :D
Old 10-26-2010, 11:25 PM   #28
Slick
Slick's Avatar
Drives: '09 3-Dr
Another update, I added the clear coat to the first piece last week and I was finally able to add the clear to two of the other pieces. So far they have came out just as I had hoped They still need a wet sand in a couple places and then some rubbing compound and polish and wax. But overall I am pleased with the way everything has come together. Let me know what ya'll think.
Again, sorry about the photo quality. Im also sorry about the lighting; its dark outside so I had to find a place with as much light as possible (queue the chandelier) lol
Old 10-26-2010, 11:49 PM   #29
custom Lftback
custom Lftback's Avatar
loooooooooking goooooooooooood
C-Lift
Old 10-27-2010, 01:19 PM   #30
2009BBPliftback
Wow
Old 10-27-2010, 03:40 PM   #31
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
looks truly amazing!
Old 10-29-2010, 06:02 PM   #32
Slick
Slick's Avatar
Drives: '09 3-Dr
HURRAY! I have fully completed 3 pieces I also have decent high res pics to accompany them Today I put the hammer down and did the final wet sand, buff, polish, and wax on 3 pieces. These pieces are ready to be put back on the car. Sorry, no car pics lol. I learned the hard way the consequences of putting on and removing trim pieces too many times. Anyway, I am very satisfied with the end result. Although I think I could have done a little better job on the bigger piece, its the minor flaws that get me But overall I am a very happy camper. I hope everyone enjoys the pics!
Thanks everyone for the comments and putting up with the other iphone pictures Enjoy!
Old 10-29-2010, 06:30 PM   #33
2009BBPliftback
The finished product is absolutly amazing! Great work!!
Old 10-29-2010, 06:41 PM   #34
maxxman420
prop215.
maxxman420's Avatar
want to put them in the car and then take pictures?
Old 10-29-2010, 07:11 PM   #35
Slick
Slick's Avatar
Drives: '09 3-Dr
Maxxxxxx: I would rather not just yet. The right side has two of the three pieces finished, but the long armrest piece is still grey. The left side only has one pieces finished. Although the finished look would be close, I believe the missing and half complete panels would really take away from the overall effect.
Old 10-29-2010, 07:43 PM   #36
maxxman420
prop215.
maxxman420's Avatar
true true, well i can't wait for the finished product. i hate correcting people but it is maxx, i got named after tj maxx hahahaha lame right
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 12:34 PM
More carbon fiber wrapping Brian Cosmetic Modifications (Exterior/Interior) 20 08-08-2010 02:02 AM
NEFFY carbon fiber wrap material cali yaris Micro Image 29 02-24-2010 08:34 PM
Carbon fiber wrapping TEHxFALLEN V1.2 Cosmetic Modifications (Exterior/Interior) 24 01-24-2009 11:05 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
