Old 12-28-2010, 09:05 PM   #19
Do you by any chance have (and know how to use) a multimeter?
Old 12-28-2010, 09:32 PM   #20
Judas Iscariot
Drives: 2008 Yaris HB
Lol. Yeah. Got one at work. And I know how to use it. Funny thing is, who owns one and can't use it. Just joking around. I'm curious to know how YOU know all this stuff tho. Your knowledge base is incredible.
Judas Iscariot is offline   Reply With Quote
Old 12-28-2010, 09:42 PM   #21
You'd be amazed as to how many people have one laying around, but have no clue as to what to do with it. I'm a EE with 20 years experience in robotics and medical automation.
Old 12-28-2010, 09:47 PM   #22
Judas Iscariot
That explains the yaris snow plow. Haha
Old 12-29-2010, 08:11 AM   #23
Judas Iscariot
Heater is ok. False alarm. I didn't put the relay in all the way. But about that multimeter....
Old 12-29-2010, 08:50 AM   #24
Here's where to start:
In the picture below (of the headlight stalk connector) measure the voltage on the sky blue wire (next to the pink wire) with respect to either of the white wires with the black stripe.
Headlights off:
Headlights on (low beam):
Headlights on (high beam):
Old 12-29-2010, 09:59 AM   #25
Judas Iscariot
voltage numbers
off- 13.8
on- 13.7
hi- .04
that last one seems funny to me, but i'm no pro.
Old 12-29-2010, 10:14 AM   #26
voltage numbers
off- 13.8
on- 13.7
hi- .04
That's fine, now same with the pink wire.
Old 12-29-2010, 11:00 AM   #27
Judas Iscariot
uh i did the pink wire first... oops, but i went out and did the sky blue one just now
off- 12.6
on- 0, yes zero
hi- 3.4
???? oh man
Old 12-29-2010, 12:25 PM   #28
OK - The off- 13.8, on- 13.7, hi- .04 makes sense for the pink, which is the high beam wire.
The off- 12.6, on- 0, hi- 3.4 is OK for the light blue, which is the low beam.
So, the headlight stalk is working correctly. Next, measure the resistance between terminals 3 and 5 of the H-LP AMT relay (they are the two larger perpendicular to each other terminals).
Also, with the H-LP relay out, measure the voltage between the pin 5 position (the large blade that is perpendicular to the other 3) and ground.
Old 12-29-2010, 12:46 PM   #29
Judas Iscariot
Ok. There is no voltage between 3 and 5 on the relay itself. But I am getting 12.88 on the housing ( where the relay plugs into) on 3 and 5. And on 5 and ground 12.88 again
Old 12-29-2010, 12:52 PM   #30
On the relay, measure resistance, rather than voltage between those two pins.
Old 12-29-2010, 01:06 PM   #31
Judas Iscariot
ah duh.... resistance is null, nothing at all
Old 12-29-2010, 02:57 PM   #32
Judas Iscariot
but if its a relay, shouldnt there be no resistance until 12v is applied to the little prongs?
Old 12-29-2010, 03:36 PM   #33
OK that's good. Now, voltage on each of the three headlight wires (on one side is fine)
Old 12-29-2010, 03:40 PM   #34
It's a normally open relay, so the resistance is infinite (displayed as OL, null, etc.) Then when the relay is powered, it goes to zero.
Old 12-29-2010, 03:49 PM   #35
Judas Iscariot
doing now
Old 12-29-2010, 03:55 PM   #36
Judas Iscariot
brown and green wire on driver side 12.88
white wire nothing... i am testing each wire to a ground right?
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
