Old 12-22-2010, 11:12 PM   #19
^ wow the first post is of someone with a first gen 1ZZ manifold adapted to the 1NZ. Sweet.
Old 12-23-2010, 01:39 AM   #20
jouna
jouna's Avatar
Drives: jdm yaris sedan
thats how we do tjings in pr lol
vvti bregao!
jouna is offline   Reply With Quote
Old 12-23-2010, 02:12 AM   #21
cfeng
Drives: Yaris 2010 Liftback
If you use too much heat wrap, you will actually cool the manifold, which seems to be the effect you want. Otherwise, increase the pipe thickness, increase surface area, increase turbulent air flow, or increase the conductivity with a new material.
cfeng is offline   Reply With Quote
Old 12-23-2010, 03:41 AM   #22
cfeng
oh wait, you mean too much heat is conducting to your manifold? in that case, any air gap/interface between the manifold and environment will be fine. And again, if you use too much heat wrap or insulation, you will have the opposite effect.
Garm's CF Wrap LA Yaris California 15 07-29-2010 07:01 PM
LEDs and heat SaerinRhoe Cosmetic Modifications (Exterior/Interior) 10 01-02-2010 09:34 AM
heat barrier auto pal DIY / Maintenance / Service 1 06-27-2009 05:29 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
