View Poll Results: Would you buy a Magnaflow catback?
Yes! 20 48.78%
Yes, but I'd rather see a center exit! 14 34.15%
Maybe 4 9.76%
No 3 7.32%
Voters: 41. You may not vote on this poll
Old 01-04-2007, 12:19 AM   #19
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Sounds nice.
Galavoxx is offline   Reply With Quote
Old 01-05-2007, 11:35 AM   #20
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
this sounds like a great idea! too bad i already bought a TRD muffler. if/when it dies, i would definately replace the exhaust system with this setup. good work on doing some investigating, charles!
2006 Red Blitzed RS 5-door
Old 01-05-2007, 12:12 PM   #21
graywolf_14
Drives: um not a yaris but hopefully
Yeah I really like the center exhuast with a dual tip.
graywolf_14 is offline   Reply With Quote
Old 01-05-2007, 12:23 PM   #22
ChinoCharles
Drives: LB
After seeing the outcome of the Megan Header R&D I was a little less enthused about making this exhaust. I began to think it may be impossible to package this so that we would see gains at any RPM other than 5500 and up. I decided to try and see if Magnaflow had already made an exhaust for the 1NZ-FE in another platform, and low and behold they did.
There are kits that sell for the Scion xA and xB now. I found them online for $450 and $500 respectively. I also noticed neither comes with a high-flow cat, which I assume means that in truth the system I speak of would be a header-back exhaust. So, excuse me for my misunderstanding of some terminology. God damn, I learn something new every day. Now, the specs on the xA and xB exhausts...
03-05 Scion xA 1.5L VVT-I Cat-back Exhaust
1.5L I-4 4dr, VVT-I, rear exit,6x6x14" p-SS muffler, 4x4x14" p-SS resonator, 2.25" SS tubing, 3.5" slash/rolled/p-SS tip
03-05 Scion xB Cat-back Exhaust
Magnaflow Stainless Steel Catback system for the 2003-2005 Scion XB, 4-DR, 1.5L, I4, VVT-Ifeatures mandrel bent 2.25" tubing with 3.5" slash-cut, rolled, polished tip. MF SS 2.25" Catback
This made me feel better about that initial 2.25" number we had decided would probably work for this car. If Magnaflow is using the same diameter themselves on a 1NZ-FE already, we should be in business.
I still wasn't convinced a system like this could make power for all 6000 RPM, though... until I found this page and the following chart... dyno results from the xB exhaust.
I'm hoping that these numbers aren't doctored up by Magnaflow. For now, its still a believe-it-when-I-see-it type deal. I am also hoping that the stock exhaust is the reason the Megan header numbers are as bad as they are. You're talking about a 2.5" outlet feeding to the stock exhaust, which I'm not even sure of the width, but I know its tiny. I have a feeling if it fed to a 2.25" exhaust, it would be a much different story.
Just wanted to share this and see if anyone had anything to add. Thanks to spkrman for the hint about referencing the Scion exhausts.
Old 01-05-2007, 01:18 PM   #23
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
$500 for so much i am sure i m getting one. it will be killer if they can make it like the minicooperS and sounds like a stock G35 lol
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 01-05-2007, 03:33 PM   #24
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Oh my God yes… the G35 has the best Exhaust note I have ever heard!
Nutzoids is offline   Reply With Quote
Old 01-05-2007, 04:24 PM   #25
spkrman
Drives: 1
hell yea, they sound awesome!
Old 01-05-2007, 07:19 PM   #26
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I'm in.
Old 01-05-2007, 08:27 PM   #27
Black Yaris
der Zeck
Black Yaris's Avatar
I am going for the twin oval center mounted tips, I am going to start with just removing my muffler, to see how it sounds. If it is ok, I will continue all the way up to the header, only with a high flow cat
Old 01-06-2007, 02:22 AM   #28
acrbill
Drives: Polar White Hatch
If you mean that you will just remove your muffler, don't do it. It will sound horrible and you will get pulled over and ticketed in short order.
I think a lot of you guys will be disappointed when you go with an aftermarket exhaust. It will wear on your nerves in a couple of months. Small displacement motors are extremely raspy when under muffled.
Old 01-06-2007, 03:55 AM   #29
ASHRAF
Scubie Du
Drives: '10 SWP STi/'09 Escalade
Send a message via AIM to ASHRAF Send a message via MSN to ASHRAF Send a message via Yahoo to ASHRAF
Please, somebody produce something for the 1.3L Yaris
ASHRAF is offline   Reply With Quote
Old 01-06-2007, 04:12 AM   #30
Originally Posted by ASHRAF View Post
Please, somebody produce something for the 1.3L Yaris[/SIZE]
Hahah well I've just asked about that on a french tuning forum, since they only have the 1.0, 1.3 and D4D versions there, there may be some options we do not know about...
Old 01-06-2007, 04:42 PM   #31
El Jefe
Drives: 07 yaris s sedan
finally im not the only one who chose 'no' lol
El Jefe is offline   Reply With Quote
Old 01-07-2007, 10:43 PM   #32
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
I'd be in once there are a few independent dynos run, pictures and some sound clips. Yeah, Yeah I like analyze and compare before buying stuff..... but it definitely sounds good so far.
Well if it’s not a hybrid how do you get such good mileage?
H8SGAS is offline   Reply With Quote
Old 01-08-2007, 07:04 AM   #33
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Smile
Same here in KSA also..with 2NZ-FE engine
ricepower is offline   Reply With Quote
Old 01-08-2007, 06:12 PM   #34
spkrman
Drives: 1
x2, i like to know what im buyin before i buy it.
Old 01-08-2007, 07:08 PM   #35
ChinoCharles
Drives: LB
I'll update once I get a chance to talk to Kevin.
Magnaflow muffler installed - vid clip spkrman Performance Modifications 3 11-17-2006 08:45 PM
Would anyone be interested??? riceboy Canada 15 10-24-2006 01:13 AM
Anybody interested on having a manufacturer make coilovers? C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-14-2006 06:46 PM
Dash Kit if interested....ebay fnkngrv Cosmetic Modifications (Exterior/Interior) 0 07-03-2006 10:18 AM
