#1 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
My exhaust technically is NOT because I did not incorporate a cat. I run a celfix to eliminate any codes. That way passing smog isn't an issue.
BUT the exhaust I am making for you guys WILL have a cat if you want one and that will be perfectly street legal. You would be surprised how well the cat flows. It will not hinder performance. |
#3 | |
Maybe have it where you can bolt on a regular axle back, and have them send ya a pipe that goes straight back with no muffler :) Is it legal to take out the stock cat? How is the long term reliability of the hi-flow cats? a setup like I just mentioned above to 60443? :) I have my magnaflow muffler, and the sound is good like it is... but as I plan to do a power adder later on, it would be nice to have the free flowing exaust for race day. I don't need anything polished etc, I'm looking to keep the cost down as much as possible. |
#4 | |
Turbo Yaris
They do flow quite well. The ones I use are stainless units inside and out that will never rust. Unlike some of the "summit" racing stuff like CATCO that isn't worth the flanges they are welded to. Now as far as legality is concerned, you are not allowed to remove the stock cats by federal law. BUT I have just changed the entire "Exhaust Line" Meaning I did not cut the cat out and run straight pipe. I am replacing parts. Really I'm stretching the rules a bit, but so does 90% of the aftermarket community. I will eventually run a cat once the turbo setup is finalized. There isn't a good argument that anyone can present to say that they shouldn't be on the car. Last edited by DTM_Yaris; 01-07-2007 at 08:12 AM. Reason: spelling |
#5 | |
Turbo Yaris
That way you won't have to spend the money twice. |
#6 |
hit me with a PM for what ya can do. No fancy stuff, just what is the cheapest that works :)
#7 | |
![]() Drives: 07 Yaris Hatchback Join Date: Jan 2007
However I would also like the "axle back" section using a resonator instead of the muffler with the same diameter (2.5") and ss piping. How much more for the axle back plus total shipping to 08054? Thanks.
2007 White Liftback 5-speed Tanabe DF 2" lowering springs, 205/50-15 on 15x6.5 Konig Helium, TRD rear sway bar, 15mm Hub spacer http://picasaweb.google.com/USAntonio/MyGarage# |
| Fujitsubo Exhaust!! | MC-BPT | Sponsors Classifieds Area | 17 | 11-16-2006 10:36 AM |
| Performance exhaust systems for yaris | aucorium | Performance Modifications | 6 | 08-16-2006 08:12 AM |
| Exhaust -- | Ziv | General Yaris / Vitz Discussion | 1 | 02-06-2006 12:57 PM |
