Old 02-16-2011, 01:30 PM   #19
^ that's not a bad idea. But if people are willing to do a little custom work, why haven't people bought the Weapon R intake?
Old 02-16-2011, 02:11 PM   #20
Focus_Sh1ft
Focus_Sh1ft's Avatar
trying to gain some bolt on performance for my yaris, the right way
This baffles me. What is the right way? Buy every bolt on performance part for maybe a 10 hp gain cumulative?
I agree the aftermarket is barely there. However, and feel free to call me narrow-minded, but if you want appreciable performance you have to get forced induction. I spent over a grand in bolt-ons before I realized I still had no chance of keeping up with soccer moms.
Old 02-16-2011, 03:00 PM   #21
car_buff
gm3 exw
Drives: 2007 yaris sedan
the right way is going all the way to the engine block, none of this axleback exhaust shenanigans, or these so cold cold air or short ram intakes that connect to the stock tb and manifold. none of those are fixing the problem, a restrictive intake manifold and cat. I intend to through it all away, the entirety of both whole systems, and replace them. the exhaust will be easier, so long as I can find a high flow cat in 2.25 diameter, because I'll be using generic prefabbed mandril bent steel, a cheap pair of used headers (depending upon the find I'd like dc's or megans, but nobody seems to be willing to part with theres unless theyve upgraded to a turbo, which is not super common) or possibly those ebay cheapies, although I'd rather not, a few of them look hardly better than a polished version of the oem manifold.
the intake is going to be troublesome, as it has several thing's attached to I don't even know what they are for. MAFS would be easy enough to relocate, but there's some rubberized hose attached to it as well, and I dunno what it's for, how it works, and how what I have in mind will effect it, even if I make a replica connection to my intake manifold. is the increased air flow going to effect whatever that thing is, and and if so, negatively or positively? for anyone willing to give a shout out...
ps. anyone know the diameter of the 1.5l tb and the 1.8l tb off the top of their heads?
btw, an example of what a real intake looks like, though a bit too much tube for my taste. i'm going to try to have them go straight down to a collector (ie throttlebody) with a wide mouth scoop under the radiator to pull off legit ram air intake mani. should be fun.
car_buff is offline   Reply With Quote
Old 02-16-2011, 03:26 PM   #22
Focus_Sh1ft
^ That's one of the PCV hoses. On my setup, I have that line going to an oil catch can, then back to the manifold.
I commend you for your willingness to make your own intake manifold, but can only wonder if it will be worth it. On NA, I doubt that it's as big of a restriction as you're making it out to be.
Btw, dunno the TB diameters, but I can tell you the 1ZZ compared to the 1NZ is a huge difference. Nearly double in size.
Old 02-16-2011, 03:42 PM   #23
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Originally Posted by car_buff View Post
The only air going in my IM (oem) is the one coming from the CAI, the other hoses are gone
I Drive a 129whp Yaris ;)
Old 02-16-2011, 03:49 PM   #24
Now I understand.
Old 02-16-2011, 07:43 PM   #25
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I have to ask this question, if you don't know what your looking at on the engine how do you feel comfortable enough in tearing it apart?
Old 02-16-2011, 09:01 PM   #26
tk1971
tk1971's Avatar
Just weighing in, as someone who has taken a car to the hilt and went full circle back to an econo-commuter.
1) The Yaris is a ~100 hp front wheel drive car. Toyota implemented an electronic power steering mechanism just to spare the engine of an additional belt driven device (I'm assuming this fact, which may or may not be true). How much more power can there be without forced induction?
2) Even with more power (I would imagine a turbo or supercharger can give a good 20-50 HP at the wheels depending on tuning and PSI). How much power is usable with the stock drive train? Remember, it's a front wheel drive car without a limited slip. How much power is too much for the transmission (whichever tranny of your choosing)?
3) I've had a 95 Civic DX once when I was younger. I fell for the ads full of girls and promises of running against Mustangs. I didn't see more power until I added a NOS kit. Then after blowing the engine, I got more reliable power with a JDM Integra Type R engine swap. Not cheap.
4) After the Civic, I got myself a V6 Maxima, then the first year IS300. The Max was a beast with cat deletes, exhaust and CAI, but it was still front wheel drive and left me wanting. The IS300 was a joke and a lemon. I swore I'd never own another Toyota.
5) I then got the first year WRX in 02. AWD was the way to go in power distribution. Engine was solid and had more power than I'd ever had with the IS300. Reliable too (in stock form). Then, I slapped a VF30 turbo on that thing, along with all the needed stuff (STI injectors, bigger fuel pump, Perrin fuel rail, cat deletes, full exhaust, electronic boost controller, and a piggyback computer with dyno map to control it all). Dynoed with comparable horsepower and torque as the JDM STI that wasn't available in the US at the time. I was perfectly happy until I busted something. As I understand it, the piggyback ECU was electrically vamp clamped to the stock ECU and something went loose, leaning out one of the cylinders. I lost compression in one cylinder after dumping over $5k into the car. I will never trust another t-tap connector again.
6) My stock EVO IX was a beast. Better than my VF30 WRX in every way. This is especially true with the brakes. Note to all tuners... Don't forget upgrading brakes if you add HP to your car. Stopping/handling is just as important as going. I left the EVO stock. Had kids and can't use it with a newborn due to the harsh suspension.
7) Had a couple more vehicles here and there. But hopefully, you get the idea about power.
I'm now perfectly happy with my stock manual tranny Yaris with only a 19mm rear sway bar. It is what it is, an econo-car for commuting. Just keep the mods in perspective with the stock engine capabilities. Don't expect miracles without spending lots of money. Happy modding.
tk1971 is offline   Reply With Quote
Old 02-16-2011, 09:16 PM   #27
Viperoni
Drives: 2005 Toyota Echo
Now I understand.
I was waiting for somebody to point this out ;)
Old 02-16-2011, 09:43 PM   #28
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I agree with Garm and the senior buys altogether. I guess I am still confused on why the OP is concentrating so hard on the intake and exhaust? If you are a car buff then you would know that those aren't going to buy you what it sounds like you are looking for in a bump. Some type of forced induction is really the only way to go to get really decent gains if you are not going to rebuild the bottom end of the motor. As for the car not having a limited slip and that literally limiting you on how much power you can put to the ground you are right, but I have also spoken with a few folks that are in the 200-250 hp range without one and they seem to do fine. I have no doubt that moving over to the LSD would net them even more real bump to the pavement. Other than a Starlet swap into my 96 Tercel this is my real foray into an import. I am used to the American muscle cars of the 60s/70s which maybe the OP is as well. Other than the B series in the Hondas what other economy (especially import) powerplants have you heard of being built for pure performance and as Garm said in a short period of years?
Old 02-16-2011, 11:29 PM   #29
357 whp is not too much. Stock trans is holding up just fine.
with the right tires and an LSD, it put the power DOWN too.
Old 02-16-2011, 11:31 PM   #30
Jason is making great power in the N/A Yaris race car. However, you can't get big gains without tuning and management.
Old 02-16-2011, 11:33 PM   #31
Your estimate is low. Customers bolting on the Zage turbo kit ($1629 shipped) and then tuning it are getting +80 whp.
Old 02-16-2011, 11:55 PM   #32
tk1971
tk1971's Avatar
Garm,
Those look like respectable numbers, but I can't compare, since all my AWD dyno experience has been with a Dynalog Dyno. All my front wheel turbo car observations are based on the turbo Neon. I consistently see them spin out on one wheel.
Last edited by tk1971; 02-17-2011 at 07:32 AM. Reason: forgot who I was talking about
Old 02-17-2011, 12:36 AM   #33
big lo
big lo's Avatar
Drives: 2007 VIOS
Wow, lol
Old 02-17-2011, 07:49 AM   #34
tk1971
tk1971's Avatar
In my case with my WRX, tuning on a dyno cost more than I expected. As a daily driver, I'd encounter on-road problems, then it's back to the tuner, etc... Gets old.
What does ~100 HP stock Yaris translate to in whp on the dyno you use? About 80? Add 80 more and that's about 160whp. What does a stock SRT4 (Neon) pull on the same dyno? Looking strictly at money (kits, install, tuning, wheels/tires, etc.), sometimes it's cheaper to start off with more. 160 wph is also about the point where an LSD becomes a good idea. I can't imagine driving in the rain w/o one at that point (expecially with stock 14's or even 15's). Just saying...
Props to you and your Yaris beast, but mine is just a daily driver and I'm perfectly happy with it. My post to the OP was to help him keep things in perspective and to have a well defined goal before spending money.
Old 02-17-2011, 09:03 AM   #35
^ Stock Yaris makes 90-95 whp. Dyno tuning costs $300-$750.
my post was to keep the numbers real, since I know what they are. And to answer your questions about (1) the stock trans (2) N/A power, and (3) what a basic turbo kit makes on the car.
Old 02-17-2011, 11:45 AM   #36
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^^ yea.. I think he bought the car on impulse and think he bit off more then he can chew.. also thinking his mind set is still set in the big displacement motors and trying to convert that knowledge to the little 1.5L.. its like going from soccer to american football.. different ball game..
ALSO, id like to point out.. even the new mustang 5.0 has an axleback muffler that u purchase separately from the mid piping.. not only that, but the CATs are welded into the midpipe as well. and a few other newer domestics now i think about it... so the concept is the same for most newer vehicles..
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Aftermarket Heads & Tails landrym28 Cosmetic Modifications (Exterior/Interior) 1 09-03-2010 08:34 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 10:14 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
