Old 08-22-2012, 09:26 AM   #19
cybrjoe
Drives: Yaris 07
My srs light is on after a big rain. I checked the code and it's " 14 ". What can i do to resolve this problem. Thanks
cybrjoe is offline   Reply With Quote
Old 08-22-2012, 09:30 AM   #20
That's a new one - "Front Airbag Sensor LH"
That would be the sensor mounted to the left side of the radiator frame that detects the impact. You will have to pull the front bumper to get at it. It has a connector that plugs into it, so the first thing I would check is if moisture got into the connector.
Old 08-23-2012, 09:38 AM   #21
cybrjoe
Drives: Yaris 07
to unplug the connector on the senso i will have to pull the front bumper ????? It is a big job??? And how can i do that. They dont have an other option to unplug it from the top. I know where is the sensor, i see it from the top but i cant see the connector.
Old 08-23-2012, 10:04 AM   #22
You don't have to completely remove the bumper, but you have to pop the top of the bumper to get to them. That just means releasing the 5 clips along the hood edge and two in the front edge of the wheel wells (which you do by pressing in the center and then pulling the whole plastic clip out) and releasing the bumper clip, where the bumper meets the fender.
This is what the sensor looks like. You will have to remove the two bolts and pull it out of its channel to unplug the connector.'
Old 08-23-2012, 10:22 AM   #23
cybrjoe
Drives: Yaris 07
thank you, your the king. I will check the connector and i will come back after.
Old 08-23-2012, 01:37 PM   #24
cybrjoe
Drives: Yaris 07
i try to reset the srs ecu but i cant. That's, what i did: short the 2 pins, srs light began give me code, open the short 3 sec, short 3 sec, open 3 sec, short 3 sec, open 3 sec and short. After that, the light gave me again the code 14. Why ?????. Is that a good procedure for yaris 2007??
Old 08-23-2012, 01:42 PM   #25
The procedure is good, so if it won't reset, chances are that the sensor is bad. To verify, you can swap the right and left (as they are identical parts) and the code should change.
Old 08-23-2012, 01:56 PM   #26
cybrjoe
Drives: Yaris 07
Is it dangerous to change sensor. I dont want the airbag blow out.
Old 08-23-2012, 02:16 PM   #27
Just disconnect the battery before doing so. Other than that there are no issues with swapping them.
Old 08-25-2012, 12:10 PM   #28
cybrjoe
Drives: Yaris 07
i switch the 2 sensors and the problem now is in the right side, so it's the sensor the problem. So now, where i can buy the sensor on internet.
front airbag sensor Part number: 89173-04010.
Thanks!!!!
Old 08-25-2012, 02:18 PM   #29
Thanks!!!!
They run about $70 plus shipping from the online parts places. I have a spare that I picked up a while ago that I could do for $40 shipped.
Old 08-25-2012, 08:34 PM   #30
cybrjoe
Drives: Yaris 07
it is a new one or a used??? And you are shure that it work. And can can i pay you. Come online to chat with you.
Old 08-25-2012, 08:41 PM   #31
It's a new one that I picked up because I thought I would need to replace the one that I posted the picture of above. It actually turned out to be fine, even though I had to bend the radiator frame away from it to get it off of the damaged frame.
I can take paypal for payment. I'll PM you.
Old 08-30-2012, 03:46 PM   #32
frambach
Drives: 2008 Liftback
Well, I've been jammed up on the DS Airbag light too. Mine is a 2008 Liftback with just a shade over 90k miles.
I'll try reading the codes but can just about assure you its the clock spring/spiral cable as it only comes on intermittently and usually when going around a turn.
Has anyone found a cheap OEM one anywhere? Seems like as much trouble as everyone's having maybe a new OEM has been revised to last longer.
frambach is offline   Reply With Quote
Old 08-30-2012, 03:50 PM   #33
frambach
Just checked the two closest 'yards' for Yaris bones and neither have one.
BTW, CTScott, you are very knowledgable and a great help. I don't post here much but that doesn't mean I don't lurk here quite a bit and glean out information for my car maintenance. Thumbs up to you.
Old 08-30-2012, 10:43 PM   #34
It doesn't have to be a Yaris one.
2007-2009 Highlander and 2006-2008 RAV4 used the same one. (Part number: 84306-22010)
Old 09-05-2012, 01:16 PM   #35
cybrjoe
Drives: Yaris 07
Thank you CTScott, i installed your sensor and it work perfectly. Thanks again !!!!!!
Old 01-09-2013, 10:51 AM   #36
jobob
Drives: 2008 sedan
question on resetting air bag
I am nervous about trying this. Is there a chance to short the wrong terminals and set off the air bag ? Do I have to connect the airbags before resetting this module using this procedure ?
jobob is offline   Reply With Quote
airbag
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
