Old 01-14-2007, 12:47 AM   #19
dngz
dngz's Avatar
Drives: black yaris sedan
1. 03Z33
2. heylookitsjames
3. kngrsll
4. acrbill
5. dngz
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
dngz is offline
Old 01-14-2007, 01:21 AM   #20
03Z33
03Z33's Avatar
Drives: TCR10
dngz, thanks for joining! I added you to the original post too :)
03Z33 is offline
Old 01-14-2007, 02:34 AM   #21
spkrman
Drives: 1
so this bolts right into place?
spkrman is offline
Old 01-14-2007, 06:02 AM   #22
punch
punch's Avatar
yeah i have a question, you say it bolts to the stock spring cups? is that the top of the springs, inside the trunk/hatch or outside the car underneath??? I don't want anything taking up my trunk space.
punch is offline
Old 01-14-2007, 08:38 AM   #23
03Z33
03Z33's Avatar
Drives: TCR10
The bar bolts underneath the vehicle to the rear trailing arm to reduce twist in the arm. It won't take up any room inside the car.
This is honestly going to be one of the simplest installs on this car, it shouldn't take more than 20 min. and simple hand tools. You probably won't even have to remove the wheels. Here is a picture of the bar on the Scion Xb/Xa:
Keep in mind that the Scion had a sway bar built into the stock trailing arm also, which we don't even have. This is going to make a big improvement on our cars!
Punch, thanks for the PM! I added you to the list
03Z33 is offline
Old 01-14-2007, 10:07 AM   #24
woof
Drives: Yaris 3dr Hatch/Black
woof is seriously, seriously interested. Right now, you're saying $140 delivered, right? Well, will it come with photographic instructions?
woof is offline
Old 01-14-2007, 10:22 AM   #25
kngrsll
Apexing Egg!!
kngrsll's Avatar
sway bar install's are one of the easiest mod's to do really.
oh, ive got a friend with a yaris, he seems intrested. i sent him the link to the thread, but he isnt that great with the internet so i may be doing all that for him, so we will see. ill try and contact him again and see whats up.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
kngrsll is offline
Old 01-14-2007, 10:32 AM   #26
dngz
dngz's Avatar
i dont think it is that simple... u gotta remove the stock sway bar first!
dngz is offline
Old 01-14-2007, 10:47 AM   #27
acrbill
Drives: Polar White Hatch
There is no stock rear sway bar.
I sure hope that its a bit more involved than the sway bar for the Scion since that sure doesn't look like it is going to do anything. Its a bar that is attached to a solid rear beam axle and nothing else. Seems like it would be like trying to stiffen a pencil by gluing a tooth pick to it. You would think it would be mounted to the chassis at some point.
acrbill is offline
Old 01-14-2007, 11:32 AM   #28
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Is the progress rear sway bar going to be similar to the one in this article? sway bar for prius.
After reading that article, I understand how the bar would reduce understeer, which is good (to a point). But how would it work in connection with (or instead of) an front upper strut bar?
Thanks!
2006 Red Blitzed RS 5-door
Doc Zaius is offline
Old 01-14-2007, 12:00 PM   #29
03Z33
03Z33's Avatar
Drives: TCR10
Yes, the price includes shipping! We may even be able to reduce the price a little more if we can get more than 25 people signed up. It includes instructions with pictures, and I will be posting instructions on the forums once I install mine.
Sounds good! Just let us know if he want's in.
That's the point! There is no stock sway bar This really will be as simple as just a few bolts, but it really does make a big difference.
It actually is very similar to the Scion design. If you study some other cars with similar trailing arm rear suspensions you'll find that this is the most effective way of controlling roll in the rear. The trailing arm is designed with a certain amount of flex/twist from the factory and this arm will help reduce the flex and minimize the roll allowing the car to corner flatter with less deflection in the rear end. Even the stock VW/Scion sway bars are mounted the same way.
Thanks!
That's a very good article, thanks for sharing! Our bars will be very similar to that one (except they'll bend backwards towards the spring/shock like the picture above). I actually had one of the straight style ones on my VW before and it works well, but requires you to drill holes in the trailing arm which would complicate the install for most. I think the way Progress do it is better for most do it yourself installers. I can't believe they charge $285 for that bar!
The front strut bar, rear strut bar (upper), and other chassis reinforcement bars can help improve your handling also by reducing chassis twist. Most of the ones that go on the front, will theoretically increase chances of understeer and bars that go on the back should increase oversteer. In my oppinion, the rear sway bar is by far the most effective one from the above mentioned bars.
largeorangefont is now confirmed, let me know if anyone else wants in!
03Z33 is offline
Old 01-14-2007, 12:10 PM   #30
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Er, what "stock sway bar?"
Chris07LB is offline
Old 01-14-2007, 12:17 PM   #31
03Z33
03Z33's Avatar
Drives: TCR10
Haha, give him a break It's not his fault Toyota cheaped out THAT MUCH and didnt' even install a rear sway bar on these cars! I wouldn't believe they still made cars without rear sway bars if I didn't own one myself
03Z33 is offline
Old 01-14-2007, 01:48 PM   #32
dngz
dngz's Avatar
HAHAHA my bad!! i just assumed the yaris would have one!
dngz is offline
Old 01-14-2007, 08:30 PM   #33
dansides
dansides's Avatar
Drives: 07 3 dr
ACRBILL add me to list for rear sway bar tks dansides
dansides is offline
Old 01-15-2007, 01:23 AM   #34
03Z33
03Z33's Avatar
Drives: TCR10
Added dansides and cdydjded to the list, Thanks!
03Z33 is offline
Old 01-15-2007, 08:18 AM   #35
punch
punch's Avatar
did you see trd now has a rear sway bar for us?
punch is offline
Old 01-15-2007, 06:47 PM   #36
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Ya... I'm wondering how much that would cost. Perhaps double the price for the Progress bar?
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 03:31 AM
C-One order 11/30/06 BulletProofAuto Sponsors Classifieds Area 15 12-01-2006 04:43 PM
