Old 04-08-2011, 03:41 PM   #19
detroiter
detroiter's Avatar
Even more reason to have "Ted" drive. Saves you the wear and tear on your vehicle :D
Old 04-08-2011, 03:42 PM   #20
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Please tell me Ted's a dog. If not he's a duschebag.
Old 04-08-2011, 09:56 PM   #21
carnageehw
Drives: 2010 Fusion Hybrid
I said earlier it was weird for your (human) friend to sit in the back seat.
It's also weird to weird for a dog to ride in the back, and to name a dog, Ted.
Whatever happens with this situation, it's weird.
carnageehw is offline   Reply With Quote
Old 04-08-2011, 09:56 PM   #22
Idahotom
Drives: 2008 5 sp. LB
A test run today of Ted's new seating position. Better, but I noticed my seatbelt (where it attaches to the side) was interfering with him being able to stick his head out the window. That may be a problem as it is legally required here in Idaho to allow your dog to do so.
I made the platform out of the remaining piece of 5/8" OSB I had leftover from building the sleeping deck. It is supported by the existing indentations at the side of the rear passenger seat, meant to be a place to rest your arms I guess. Two short pieces of 1x2, positioned and screwed after the deck is in place, take out side to side slop, and there will be some, as if you cut it to fit tight, you can't get it in. That chunk of 5/8 weighs 11 lbs, and as soon as I come across a thin sheet of paneling, like 1/8" or so, I'll use that and stiffen it with some aircraft grade spruce, cut into 1x2's, left over from a '46 Taylorcraft wing rebuild. End weight then will be about 3 or 4 lbs.
To keep it positioned fore and aft, two struts (old ultralight aircraft wing rib material) attach to the deck (castellated nuts and a hairpin clip, for quick removal) and the rear fitting that I believe is there for the rear deck to pivot on, don't know I removed that stuff long ago. The only hole or mod to the car itself were the 3/32" holes in the rear strut attach point, and that will not effect it's original use much if at all.
This is better, but I (and Ted) still really need a 4 door, with power windows. Cranked half down, and the front heat on, that is how we roll all winter in the All-Trac except for the interstate. I frigging spoiled him, now he expects it. He went from zero knowledge of the proper way a dog rides in an Idaho rig (got him at the pound 3 years ago) to now expecting it no matter what. I do get a vicarious kick out of how much he enjoys it, it looks like great fun! If only the rear windows rolled down, even halfway! Sorry if I gave the impression in earlier posts I was talking about a person
Idahotom is offline   Reply With Quote
Old 04-08-2011, 11:48 PM   #23
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I hate to be the one to break this to you. But that's not a dog, it's an Ewok!
Old 04-08-2011, 11:51 PM   #24
nemelek
DWEED
nemelek's Avatar
When my fur ball died it took hours to shop vac the car out. The wife got the next dog and it's only allowed in the truck.
Old 04-09-2011, 12:07 AM   #25
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Well dammit, why the hell didn't you just say he was just an ankle-biting dog in the first place? LOL
Old 04-09-2011, 12:44 AM   #26
frownonfun
frownonfun's Avatar
lol... literally.
I crush you like tiny clown car, because you are clown, yes?
Old 04-09-2011, 03:09 AM   #27
fluke_boy
Drives: 2010 Yaris 3 dr hb
Holy shitsnacks, Ted's an ewok - lol.
Props to Altitude.
fluke_boy is offline   Reply With Quote
Old 04-09-2011, 01:09 PM   #28
2009BBPliftback
2009BBPliftback's Avatar
That photo had me lolin for sure.. Ted doesn't look happy...
2009BBPliftback is offline   Reply With Quote
Old 04-09-2011, 06:41 PM   #29
STC
"LibertyRides!"
STC's Avatar
LOL! Are you sure that's Ted? Looks like a Tersesa instead!
Cheers!
~ Mark ~
Old 04-13-2011, 06:17 PM   #30
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Sorry to break it to you OP, but Ted needs to ride in a crate. Unless you've also fashioned a doggy seat belt??
D&D is offline   Reply With Quote
