Old 07-23-2015, 12:21 AM   #19
Murtaza_murti
Drives: Toyota Belta
This vibration issue still persists. It's very annoying, it goes away when you clean the spark plugs but after 500-600 kms the vibration comes back again.
Any solid solution to this, anyone?
Murtaza_murti is offline   Reply With Quote
Old 07-23-2015, 01:52 AM   #20
bail_w
Drives: 2007 Toyota Yaris LB
Then replace the spark plugs?
bail_w is offline   Reply With Quote
Old 07-23-2015, 08:55 AM   #21
valchrist90731
Drives: 2007 toyota yaris sedan
Replace starter and check battery and alternator.
When was last tune up?
valchrist90731 is offline   Reply With Quote
Old 07-25-2015, 05:42 AM   #22
Murtaza_murti
Just replaced them 1,000 kilometers back.
It's the vibration that is annoying. This thread is old, the rough start was due to an old battery, had replaced it and that issue was resolved.
Old 07-25-2015, 11:20 AM   #23
valchrist90731
STP super concentrated Fuel Injector cleaner*
Don't use this crap.
Old 08-11-2015, 07:04 PM   #24
Murtaza_murti
Used it once, years ago. I would never use it anymore.
Old 08-15-2015, 12:45 PM   #25
ricardocanedo621
ricardocanedo621's Avatar
Drives: 2008 Yaris Base
For the hard starting you might want to replace the Engine Coolant Temperature sensor. They can be defective even with no check engine light. What's probably happening is that the ECT is giving an incorrect reading and the car is getting too much fuel at start up and may be causing fouling of the Spark plugs and hard starting symptoms.
Last edited by ricardocanedo621; 08-15-2015 at 01:01 PM. Reason: Correcting Grammatical Errors
ricardocanedo621 is offline   Reply With Quote
Old 08-15-2015, 12:58 PM   #26
ricardocanedo621
Part Number: 8942233030
Amayama.com has it for $22 USD and ships worldwide
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
Rough engine start w/76? guyver408 DIY / Maintenance / Service 12 06-26-2009 12:18 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
