Old 05-10-2011, 12:24 PM   #1
Yarice
Yarice's Avatar
Drives: 2008 LB Meteoric Metallic
Racland Coilovers for Yaris
Hey guys, I just got off the phone with Raceland and they confirm that the Yaris coilvers are out now. I just ordered a set and will be installing them as soon as I get them. I'm also with the Miata community and I have only heard only good things about there Coilover kits. At $329, why not give them a try. The kit does say Scion 1 Gen XB/Yaris but like the tech said it will fit. The front spring rate is 275, rear are Progressive Rate Springs. They have already test fitted on a Yaris LB and the coilovers and rear springs have the exzact mounting points as the 1 Gen XB. Raceland has assured me that it will deffinitly fit. The only issue is these were made for a 3000 lb vehicle so ride qualitiy might be a little different. Racelands said if you don't like the ride, return them. If for some odd reason they don't fit, they will take it back within 30 days. There customer service is second to none.
http://www.racelandus.com/p-149-coil...b-1st-gen.aspx
Yarice is offline   Reply With Quote
