#1 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
horns are dead easy. Find a 12v battery, splice the wires, see which side is groun and power, then screw the ground into somethign near the front grill, and splice the power into the original horn. Done.
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
^^^ BOOM
#3 |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#4 |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
hey guys/gals why not get the Piaa horn kit from Amazon for cheaper? - http://www.amazon.com/o/ASIN/B00067BWBI/?tag=dp-us-20
#5 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
The Toyota premium horn kit (from eBay) contains two horns at two different frequencys to give the clasic horn sound. It also contains the wire "Y" harness and mounting hardwar for a Toyota. It is a better value IMO. It's what I installed in my Yaris an it's great.
#7 |
#8 |
Anybody with pics of the premium horn kit installed? Trying to get a feel for placement as it sounds more and more like a good idea. Thanks (pics worth a 1000 words)
Just said the hell with it and got em. Need the pics now for ideas. Thanks |
#9 |
If you go to the ebay auction in the link there are pictures there.
#10 |
Great choice.
Here's a DIY with pics. Scroll down the page. http://www.yarisworld.com/forums/sho...t=horn+install You do not need to remove the bumper if you do it as described. I had plenty of room doing it that way. You can get creative as to how to mount the horns. You can drill another hole as shown. However, I just made a small bracket (out of metal I had on hand) which I mounted both horns on. I then mounted the bracket (with the horns mounted on it using the existing hole. This way I did not have to cut any plastic, etc. Last edited by RedRide; 05-25-2011 at 07:11 PM. |
#11 |
Thanks for the link and comments.
#12 |
Well got mine from the Ebay dealer as advertised. Spent today removing bumper and steam cleaning. Dressed all the plastic parts, installed the horns and put it all back together. Kit came with the bolt etc to fit the empty threaded hole left of the stock mount. Great sound. Thanks to all in this thread for replies and links. I appreciate it.
#13 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
put in a set of hella supertones and call it a day!
http://www.youtube.com/watch?v=eES0b7MO-eQ&NR=1 makesure you use a relay! |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
| Horn Relay? | MGargano | DIY / Maintenance / Service | 7 | 11-14-2009 06:01 PM |
| HELP! SRS light won't go off, horn doesn't work | kudzu71 | DIY / Maintenance / Service | 11 | 08-18-2009 05:12 PM |
| Toyota Premium Horn | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 22 | 02-18-2009 11:28 PM |
