Old 01-20-2007, 10:26 PM   #1
tmyers82
Drives: Toyota Yaris Hatchback
Strut tower bar
Does anyone know if a Scion XA bar will fit the Yaris. I tried to ask the guy in the parts department at the dealership and he looked at me like I was an alien.
tmyers82 is offline   Reply With Quote
Old 01-21-2007, 12:25 AM   #2
Originally Posted by Yaris TTE JWRC View Post
NO, NOTHING FOR FOR THE SCION XA, XB WILL FIT THE YARIS, YARIS IS A TOTALLY DIFFERENT CAR, THE REASON I KNOW BECAUSE I BOUGHT MOST OF PARTS DESGINED FOR THE SCIONS FOR MY ECHO, AND NOW I HAVE A YARIS, SO I KNOW THAT YARIS IS A TOTTALY DIFFERENT CAR, AND NOTHING FOR THE SCIONS WILL FIT THE YARIS, NOTHING!!! PERIOD
Dude ease off the caffeine a bit
Old 01-21-2007, 12:00 PM   #3
ChinoCharles
Drives: LB
LOUD NOISES! I DON'T KNOW WHAT WE'RE YELLING ABOUT!
(Anchorman. LOL)
Old 01-21-2007, 12:04 PM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
What about the carpets?? Not sure... but you can give it a try
Old 01-21-2007, 12:09 PM   #5
CASTREX
CASTREX's Avatar
Well..... then you will have to settle with the shiftknob...
Old 01-21-2007, 11:44 PM   #6
EddyCocaine
EddyCocaine's Avatar
Drives: Soon To Be Blue Liftback.
Caps Lock!! its like cruise control for awesome!!!!
EddyCocaine is offline   Reply With Quote
Old 01-22-2007, 02:08 PM   #7
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Yaris TTE,didnt you say nothing for the Scions would fit,man your full of HOT AIR,The crank pully's will also fit,I have a freind who has confirmed this.Ohya,we have the same engines,so the internal parts sold for the XB/XA should also fit,like pistons,rocker arms ext...
eco is offline   Reply With Quote
Old 01-22-2007, 02:33 PM   #8
ChinoCharles
Drives: LB
Old 02-05-2007, 11:28 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
No, the crank pulley will not fit, the Yaris crank pulley one only holds one timing belt, Scion, Xa, Xb, and echo's crank pulley holds two timing belts, i know, because i have the Perrin Lighten Crank pulley on my Echo when i installed myself, and it is desgined for Sicon, as i look at my Yaris's crank pulley i could see it only holds one timing belt, so they are not the same , nice try buddy.
These engines don't have timing belts.
Old 02-06-2007, 12:40 AM   #10
ZPIracing
ZPIracing's Avatar
Drives: Scions
crank pulleys are different. The Yaris runs a single accesory belt the xB/xA runs a dual. You would not want to run an xB pulley even though it may bolt on the balance is wrong.
ZPIracing is offline   Reply With Quote
Old 02-06-2007, 01:34 AM   #11
You're both rigtht and wrong, the Yaris uses a timing CHAIN (which connects the crankshaft to the camshafts), and a single accessory BELT which connects the crankshaft to the alternator, air conditioning compressor, etc. You don't see the timing chain from the outside of the engine as it has a cover on top of it.
Yes, it's a lot of semantics, different words for more or less the same thing, easy to get confused.
The echo and xA/xB use two accessory belts as they have a traditional pump based power steering system, while the Yaris' is electric, meaning the extra belt is not needed. Which is why aftermarket Scion pulleys CAN fit on the Yaris, but they'll have an extra groove for that second accessory belt, which is more or less useless.
Anyway this thread is starting to turn a little too nasty, I think we now all need a timeout to re-read what everyone wrote and try to understand each other a little better, OK? Yaris TTE WRC is trying to help and share his experiences, but his choice of words is not always quite so helpful!
Old 02-06-2007, 02:11 AM   #12
ChinoCharles
Drives: LB
Yarii have electric power steering... unusual.
Old 02-06-2007, 03:48 AM   #13
spkrman
Drives: 1
hopefully you already knew that :)
its one of my fav things about the car.
Old 02-06-2007, 06:52 AM   #14
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
ditto
will work for parts
Old 02-06-2007, 12:20 PM   #15
ChinoCharles
Drives: LB
I only found it out during the NST GB. For a second I thought the car had no power steering, like a Festiva.
Old 02-06-2007, 02:03 PM   #16
PetersRedYaris
Do you even know what a timing belt is?? how can an engine run without a timing belt, how are you going to run the water pump and powersteering?
I do! Apparently you don't as eTimago had to explain it to you. Use the correct terms. It's a chain, NOT a belt, and is internal, as opposed to external with a plastic cover over it. People may interchange the terms accessory and timing when talking about belts but they are not even the same thing nor do they serve the same purpose. One reason I like this 1.5 liter motor is because it does NOT have a timing belt. That means no expensive timing belt replacement/service. You probably feel dumb now, I'll let it go.
P.S. We have nearly the exact same car, even the color is the same. We should be friends!
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 07:46 AM
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
