Old 09-08-2011, 02:27 AM   #19
spiceyhotwings
Drives: 2009 Yaris RS 5 door
Is the relay light blue and have the part # 90987-02027 on it? If so then I have the right part.
my new 2009 Yaris RS 5 door
spiceyhotwings is offline   Reply With Quote
Old 09-08-2011, 06:58 AM   #20
Yes
Old 09-09-2011, 03:03 AM   #21
spiceyhotwings
The relay had a reading on one pair of terminals and the other pair of terminals did not register a reading at all. Does that mean that the relay is good or bad?
Old 09-09-2011, 06:41 AM   #22
That would theoretically mean that it is good.
Old 05-20-2012, 09:48 AM   #23
ggrieco
Drives: 2008 yaris aero
Hey Scott,
I tried your mod for havong the fogs run independent from the other lights and it did not
work. I also noticed a similar post that says to splice the orange wire at pos 4 to the white wire at pos 13.
What gives.
Gary
ggrieco is offline   Reply With Quote
Old 05-20-2012, 09:58 AM   #24
Originally Posted by ggrieco View Post
Hey Scott,
What gives.
Gary
You've got too many threads going now on this, but as far as the pin 13 versus others go, there are many ways to skin the cat. Jumping to 13 makes the fogs only work when the headlights are on (but with either high or low beam), whereas normal operation is only with low beams and grounding makes them work at any time, even without the headlights.
Old 05-20-2012, 07:51 PM   #25
spiceyhotwings
I need to print this install chart on paper for keeps.
http://www.toyota-tech.eu/aimuploads...01%20190-1.pdf
Check it out, it might help you out too.
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
Need some help with Fog Lights on 09HB Pikachu DIY / Maintenance / Service 1 07-06-2009 01:40 PM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
My ebay fog lights and led interior light pics Julz Photo-Video-Media Gallery 6 09-13-2007 10:41 AM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
