Old 02-06-2007, 04:59 PM   #19
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Guys... check out Konig's website... they show the bronze Heliums in 15" & 16", and then again in 17" & 19". There are *2* different bronzes depending on size... its right there on their site.
2006 Red Blitzed RS 5-door
Old 02-06-2007, 05:02 PM   #20
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
You got it Doc!
The 15/16 Helium Bronze is VERY bronze. Brilliant colour.
The 17/19 Helium Bronze is somewhat bronze when there is lots of natural light, but extremely gunmetal. If you take a look at the picture I took of the wheel on a sunny day, you'll notice that it is not nearly as bronze as Ashley's wheel.
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 02-06-2007, 05:07 PM   #21
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
i like the big bronze colour better than the little bronze colour anyway! (IMO!)
Z
Old 02-06-2007, 05:09 PM   #22
bigsky2
Cousin Vitz
bigsky2's Avatar
Sorry to thread hijack like this
I'm very confident that there is a difference in "bronze" colour among the 15/16 and 17/19 as Doc pointed out.
Anyhow, I just wanted to say that your Yaris looks great, and I like the colour of your wheels
Old 02-06-2007, 05:57 PM   #23
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
No problem. Your wheel definately is lighter. I'm sure they will look great on the car none the less.
Old 02-12-2007, 10:37 AM   #24
mrrock
Drives: yaris 2dr hatch
I've got the Tanabe NF's and 205/50/16's on BBS and I've had to modify the front inner plastic liner so they don't rub: bent the front and back metal tabs and then used a heat gun to modify the plastic liner at the tabs
mrrock is offline   Reply With Quote
Old 02-12-2007, 12:50 PM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
Ya'll are rubbin with 205's? What offset are you running.. I have 225/50R15's with absoluly no rubbing.... and I have plenty of room to lower... Teyrume with the supercharged Hatch is running the same size as me and he is lowered with no problems.... Ya'll must be running an odd offset
Old 02-12-2007, 01:28 PM   #26
dansides
dansides's Avatar
Drives: 07 3 dr
what offset do u have black yaris i would like to go to 225 50 15 but do not want them 2 proturde out past fenders also how many inches of tread meets the pavement .tks dansides
dansides is offline   Reply With Quote
Old 02-12-2007, 02:34 PM   #27
bigsky2
Cousin Vitz
bigsky2's Avatar
Strange but I am running 205s as well and I experience no rubbing.
205 40 R17 tires on TRD Springs (Eibach Pro rebadge). About a 1.2" drop front and rear.
Rim is Konig Helium 17 x 7, 38mm offset I believe.
Old 02-12-2007, 08:02 PM   #28
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I had the same issue running 215/45ZR17. I actually had to change my fronts to 205/45/ZR17s so I wouldn't rub. The rears were and are fine. So right now I'm running two different tire sizes until I wear them out. I believe I have a +43 offset. Before I found this board, guys at Toyota told me 43 is what I should run. Tire guys didn't see a problem with that but the front inner fender has a weird shape and when I lowered it with the 215s, I rubbed a bunch and did some hacking to the plastic to remedy. It helped but I still had to change to 205's. Even with the 205s, I get some minor rubbing on u-turns.
Galavoxx is offline   Reply With Quote
Old 02-12-2007, 08:06 PM   #29
bigsky2
Cousin Vitz
bigsky2's Avatar
Is it because you guys have too much sidewall?
All the people I have met that are running 17's on the Yaris (lift/hatchback specifically) are running 205-40 R17 tires as oppossed to 205-45.
Wondering if that might solve your problems..
Old 02-12-2007, 09:28 PM   #30
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
That's what I was also told. And given that my current setup only rubs on u-turns, I imagine 40s wouldn't rub at all. I really like a little more meat on my tires though. The 40s are so skinny. Not to mention road noise is already bad enough.
Old 02-12-2007, 11:29 PM   #31
largeorangefont
Break'em off some.
My tires rarely rub with 205 50 16s. My wheels are 16X7 +40 offset. Only on hard turns at speed, or large dips at speed will the tires rub the inner fenders in the front. The TRD strus should keep it from rubbing on all but the largest bumps at speed.
Old 02-19-2007, 10:21 PM   #32
"G"
Drives: 2007 Yaris Hatch
looks good.
"G" is offline   Reply With Quote
Old 03-12-2007, 10:57 PM   #33
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
When u guy rub during u turns, which part of the wheel does it rub ? If it rubs on the inside, more offset will make things worse.
I'll probably be getting some 16 x 6.5" and with +40 offset together with 205/50R16. With a 6.5" wheel at the same offset as you, the wheel should sit inside just a little bit more.
What do u think ?
nurburgring is offline   Reply With Quote
Old 03-12-2007, 11:02 PM   #34
Black Yaris
der Zeck
why are ya'll runin the wrong offsets? 7 inch wide should be +38 nothin less, nothing more.... on a 6.5 you have a bit to play with... so a +40 would work no problem with no rubbing issues at all
Old 03-13-2007, 01:40 AM   #35
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I'm having rubbing issues on the back tires of my sedan.
The wall of the tire rubs the edge of the fender.
This is my set up:
Hankook R-s2 W212 205/50ZR15
Konig Heliums 15"
Tanabes DF 2" drop
Weird thing that my car is only rubbing on the left side.
Don't want to go to down to 195 tires or to a more conservative 205. I just need like 4mm to clear the tire so I will probably do some cutting.
Old 03-13-2007, 12:43 PM   #36
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Wink No problem with...
I recently installed my Tanabe NF210 front 1.0f - rear 1.3 with 16" 205/45/16. No problems. I will post new pic in my garage soon.
rwseattle is offline   Reply With Quote
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Got new wheels, tires, and springs installed. largeorangefont Photo-Video-Media Gallery 8 01-22-2007 04:29 PM
Just put my new wheels on Ryosuke Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-18-2006 01:04 AM
Lets talk wheels birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 80 04-29-2006 01:13 AM
