Old 01-07-2016, 07:55 PM   #19
Frank the Tank
Drives: 2007 Toyota Yaris
Bringing this back from the dead
I found a couple of sets of seats online from a 7th gen celica.
Want to know if these are direct bolt on before I pull the trigger
Frank the Tank is offline   Reply With Quote
Old 01-08-2016, 12:50 AM   #20
bladesmith6
Drives: 2007 yaris HB
Unfortunately i don't think any gen of celica is a direct fit. I bought a set on some elses advise and found that the brackets did not match up. By the time you fabricate a new bracket and clean the seats up it might be better just to buy a set of racing seats that will bolt in.
bladesmith6 is offline   Reply With Quote
Old 01-08-2016, 08:53 AM   #21
The rail width is the same as the first gen '99-'05 chassis. Not sure about the newer gen. I have Celica seats in my car, but I had to swap the rails from my stock seats to do it. I was quite involved because the rails don't unbolt, they had to be disassembled.
Old 01-08-2016, 12:15 PM   #22
Frank the Tank
Can you post pics of the seats in the car and the rails
Old 01-08-2016, 12:20 PM   #23
Not much to see from the rails. Only difference was the physical locations of the bolting points from the Echo seats to the Celica seats.
I'll snap a pict later for you though.
Old 01-08-2016, 09:10 PM   #24
Frank the Tank
Thanks, the more the better
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
Lower Seat Height? BassAssassin Cosmetic Modifications (Exterior/Interior) 47 02-25-2010 10:14 AM
