Old 10-31-2013, 07:12 AM   #19
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'll dig up my spreadsheets and see what info I'm missing. I think I accidentally deleted my part number workbook and only have a partial record from a previous version...
Old 10-31-2013, 08:22 PM   #20
Jerkratt
Jerkratt's Avatar
Please and thank you I'm gonna have to go scavenger hunting anyway to find the trans 's I need
"It hurts more when its wet"
Old 10-31-2013, 11:07 PM   #21
CrankyOldMan
Well, here's what I have so far. One spreadsheet is a list of OEM part numbers, if you want to either buy them new or find what donor vehicles should have them. The other is a sandbox for evaluating different ratios. It's up to you to put in the right values, but it will show you the change in top-end speed for a given setup. The tradeoff for lower top speed is more torque, but this doesn't factor in the torque curve of the 1ZZ. The doc is a collection of different configurations. If you can't see it in MS office formats, I can try and post them as PDFs instead.
Old 11-01-2013, 12:00 AM   #22
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Heya Jerkratt - If you end up having to have tools purchased to do the work let me know as I might be interested in going in on it with you for my transmission mods I need to have done!
Old 03-24-2014, 10:10 AM   #23
fnkngrv
fnkngrv's Avatar
I have started a new group on Facebook called "Toyota 1NZ Enthusiasts Garage. There is interest on what can be mated with the 1NZ to include I believe even transaxles. I will be posting up this information in a document there as well.
Old 07-16-2014, 07:41 AM   #24
CrankyOldMan
So I finally got around to counting the teeth on all the gear sets I've acquired. Turns out there were a few surprises!
C50 (Yaris and xB): as expected
C56 ('03 Celica): as expected
C59 ('07 Matrix): 4th gear actually 0.886:1 (31:35)
Differentials for C56 and C59: may be the same as the xD. RagnaCaT on microimage is in the process of swapping an LSD into an xD gearbox to put on his Yaris and discovered that the xD has a different differential, despite having the "same" C50 gearbox.
Looks like it's time for me to go back over the spreadsheet and find out if I'm using that new 4th gear ratio.
Old 07-16-2014, 09:43 PM   #25
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Something that would be nice to look up is the 2014 corolla 6 speed MT they still have the 2ZRFE and our tranny bolts to them maybe just need XD axles also... Do you know where we can look it up?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 07-16-2014, 09:48 PM   #26
fnkngrv
fnkngrv's Avatar
As a heads up your original graph is a bit off in the estimates as I have the stock C50 still and currently my top speed on the dyno sits in the mid 160s. This is at the 7k redline.
Old 07-16-2014, 10:06 PM   #27
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
As a heads up your original graph is a bit off in the estimates as I have the stock C50 still and currently my top speed on the dyno sits in the mid 160s on pump gas and the ~250hp. This is at the 7k redline.
Maybe his qoute is at the 6400 redline thats why its below the 160 I will soon be testing the 3.94 ratio I think its in the middle of performance and economy.
R-CaT
Project Yar 2ZR
Old 07-16-2014, 10:15 PM   #28
fnkngrv
fnkngrv's Avatar
If you look at graph he has presented he does show the continued elevation past the 6250 redline. In some parts of the world it is actually 6500. His graph is theoretical in nature anyway, but I figured that I would share the disparity. He and I have been discussing this topic for months via PM.
We are both very intrigued with the entire scope of the subject. It also has been very educational for me especially when I talk with other parties that have no experience with the powertrain in the car and thinking that it is easy to increase the ability for top speed by changing gearing not realizing that there is very little support for the platform.
Old 07-16-2014, 11:06 PM   #29
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Your right I was refering to the wrong graph the 1st and didn't notice the rpm's in the second. The wheel size aldo affect the equation what size of tire was taken in to account?
This attachment I made can help you guys made this when hunting for the 3.94 final
File Type: doc Yaris RPM and Gear Speed Calculator.doc (171.5 KB, 4 views)
R-CaT
Project Yar 2ZR
Old 07-16-2014, 11:12 PM   #30
fnkngrv
fnkngrv's Avatar
very good point about the wheel and tire configuration. I am currently running 205/55/15.
Old 07-16-2014, 11:17 PM   #31
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
My yaris has 195/50/16 this the exact height as OEM 185/60/15, intresting is that with 195/50/15 would give the same affect as 3.94 FD.
R-CaT
Project Yar 2ZR
Old 07-17-2014, 07:23 AM   #32
CrankyOldMan
The spreadsheet I use has a built-in reduction for "rolling radius" on the tires to compensate for the "perfect" geometry of calculating the tire diameter/circumference. I don't remember what tire size I had selected for that particular screenshot, so that could be a factor, too.
I think the spreadsheet is more useful as a comparison of ratios. As an engineer, I appreciate the value of a mathematical model, but I put more faith in the empirical evidence than the simulation.
Old 07-17-2014, 11:05 AM   #33
Jason@SportsCar
Does the xD have a different final drive and output shaft as well, or just the diff? *I know it is a different ratio, but is it physically different to the point it wont swap...
Old 07-17-2014, 01:22 PM   #34
CrankyOldMan
I was able to close the Yaris C50 with a C56 and C59 differential in it, but I never checked the preload. From what I understand of RagnaCaT's project, the xD differential housing is large enough that the final drive ring gear from a Yaris will not seat on it. I took my ring gear off the xB diff--which is the same as the Yaris--but haven't dismantled the C59 or C56 diffs yet to measure their critical dimensions. That said, the C56 pinion shaft seems to mate correctly with the xB's ring gear, but I still have to do the preloads and whatnot.
Are you hoping to use the larger diff and output shafts from an xD for better power handling, or some other reason?
Old 07-17-2014, 01:36 PM   #35
CrankyOldMan
I've just realized that up to this point I've been referring to the pinion shaft as the "output" shaft. Now that the output/drive shafts are in the discussion, I should probably stick with "pinion" for the shaft between the input and differential from now on, yes?
Old 07-17-2014, 01:38 PM   #36
Jason@SportsCar
No, looking to build my spare trans with a 3.9fd for faster tracks. With the 4.3 and Kaaz gear set I am on the limiter (7500rpm) in 5th at some tracks.
changing gear from robotic to automatic mariann DIY / Maintenance / Service 13 12-09-2011 06:43 PM
Gear Ratios J_T Performance Modifications 1 06-16-2011 12:31 AM
Changing Gear Oil Of the C160 Parmas DIY / Maintenance / Service 12 01-20-2011 02:44 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Gear Ratios? aephilli DIY / Maintenance / Service 3 04-12-2007 05:38 PM
