Old 09-25-2011, 05:18 AM   #19
Nas_RS
Vitz_RS
Drives: Toyota Vitz RS NCP91
Anyone who can help me getting the ECU, please let me know
Nas_RS is offline   Reply With Quote
Old 09-25-2011, 08:11 AM   #20
The Yahoo.jp auctions will be your best bet for finding one.
Are you driving the car now, or is it just sitting waiting for an ECM? If it is just sitting, why don't you ship me the bad ECM and I will see if I can fix it for you.
Old 09-25-2011, 08:26 AM   #21
Nas_RS
Vitz_RS
Yeps just sitting for now and the car is at the mechanic garage, the ECM is with him
Old 09-25-2011, 08:28 AM   #22
Nas_RS
Vitz_RS
How to buy on the Yahoo.jp auctions can you help pls.
I guess the cost of sending the ECM and time it will take to reach you from where i am in Mauritius, will cost me another ECM :)
Old 09-25-2011, 09:41 AM   #23
This is a good site for info on how to purchase things via yahoo.jp:
http://www.ffmusic.info/yjtutorial.html
Old 09-25-2011, 10:20 AM   #24
Nas_RS
Vitz_RS
Thx Dude, i will take a look at it :)
Old 09-26-2011, 02:56 PM   #25
Nas_RS
Vitz_RS
Hello, CTScott..
My ECU Ref is 89661-52b10..its very difficult to get it in the market..
The ignition number is not getting power..
Any idea, repair, purchase, possible for another model example: 89661-52g10... can match
Old 09-26-2011, 04:30 PM   #26
Originally Posted by Nas_RS View Post
Hello, CTScott..
I think the 89661-52G10 would be fine. 89661-52B10 is for the NCP91 with the 1NZ-FE built from 05-07 and 89661-52G10 is for the NCP91 with the 1NZ-FE built from 2007-2009. Do you have a Toyota dealer where you are that would be able to deal with the reprogramming of the smart entry system (which requires the Toyota TechStream service tool to do)?
Last night I did some analysis of the ignition outputs and found that they do not go through a transistor, but rather are direct outputs from the Denso SE742 PWM Driver IC circled in the picture below. So, repairing your existing ECM would require swapping that IC with one from another ECM (it would be difficult to purchase that IC otherwise, as it is not an off-the-shelf item).
Name:  ECM - Bottom2.jpg
Old 09-28-2011, 06:36 AM   #27
Nas_RS
Vitz_RS
Lots of thanks for these info, helpful.
I get the car retutn from the garage. Can interchange the ignition and spark plugs to test if the third ignition is working, i want to check the wiring myself, i believe an ecu dont get damage easily, i can also buy another ecu to my ecu ic. We have a toyota dealer here they dont repair ecu but they reprogramme thats fine :) one thing gud
Old 09-28-2011, 09:00 AM   #28
Nas_RS
Vitz_RS
I am getting that also but not b10, but b00
http://www.importmonster.com.au/view...ion/s220179421
Old 09-28-2011, 09:23 AM   #29
B00 is for the NCP91 with the CVT, so that wouldn't work for you.
Old 09-28-2011, 02:38 PM   #30
Nas_RS
Vitz_RS
Hello, CTScott..
The Diagnostic Report is:
Total Codes: 001
Code001:
P0353 Ignition Coil C
Primary
Secondary
Circuit
Malfunction
Any idea, is it concern for the ECU
Old 09-28-2011, 03:40 PM   #31
Hello, CTScott..
Total Codes: 001
Code001:
Primary
Secondary
Circuit
Malfunction
My money is still on the coil pack. I would swap the #3 coil pack with one of the others to see if the problem moves to another cylinder.
Old 09-28-2011, 11:00 PM   #32
Nas_RS
Vitz_RS
The coil pack is the stuff that come on the top of the spark plugs, i'm right
Old 09-28-2011, 11:04 PM   #33
Yes
Old 09-29-2011, 04:10 AM   #34
Nas_RS
Vitz_RS
Okie, i will try swap or get another to check. Is it possible to swap wire also?
Old 09-29-2011, 06:33 AM   #35
No. The wire is part of the whole engine harness, as opposed to being a traditional spark plug wire.
Old 09-29-2011, 11:00 AM   #36
eseibel67
eseibel67's Avatar
Drives: 2007 Yaris
If I was diagnosing a #3 misfire on a desert island, I would swap #3 and #4 coil packs and see if the problem follows the part.
eseibel67 is offline   Reply With Quote
Connects2 UNI-IR Universal Infrared Steering Wheel Control Interface rognewton In Car Entertainment + Electronics (audio / video / alarm) 0 05-04-2011 09:42 AM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
