Old 10-14-2011, 08:59 AM   #19
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Ok, found some info on the 1ZZ.
* 87.5 mm cylinder spacing.
* 41 x 413 mm runners
I measured the flange on the manifold and found that the runner spacing is also 87.5 mm, and the ports are 35 x 52 mm elliptical.
Update:
I found some info on the 1NZ cylinder spacing:
cylinder bore: 75mm
cylinder wall thickness (between bores): 8mm
cylinder pitch: 83mm
That should make the header pitch 83mm as well. Now to figure out the opening dimensions and bolt locations...
Old 10-18-2011, 04:55 PM   #20
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Monchy huevon t dije q brega!!!!
Here's on a friends Yaris N/A 115whp
Here's on a friends Yaris Turbo/Nos 305whp
I Drive a 129whp Yaris ;)
Old 10-18-2011, 08:50 PM   #21
Viperoni
Drives: 2005 Toyota Echo
Maybe that type of manifold works better for boosted cars than N/A, I had a buddy of mine (with a B.Sc in ME, built an IM as a part of his schools Formula SAE team, and worked for GM) tell me that it's tough to implement properly on N/A cars and a typical runner+log manifold works better.
2006 Saturn Ion Redline
Old 10-18-2011, 09:01 PM   #22
Well it was stock on the corolla so it must be good enough
Old 06-17-2012, 04:59 PM   #23
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Monchyxb and YarisPR...
Just wanted to thank you guys for inspiring me to do what you did.
Custom Short Ram Air Intake Problem laxsaint99 DIY / Maintenance / Service 10 04-27-2011 01:28 AM
Custom Intake manifold/w 1zz tb / direct port nitrous blacksandiegovitz Items for Sale by private party 28 11-23-2010 08:57 PM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
My Custom Intake RacerFreakXXX DIY / Maintenance / Service 7 12-21-2008 07:32 PM
