Old 10-24-2011, 06:26 PM   #19
Reactor
Drives: 1nz-fe
ECU will learn by how much to offset MAF sensor readings that are affected by different intake runner diameter. The Long Term Fuel Trim value will eventually be in the plus territory since ECU will assume that MAF does not measure as much air as is actually entering the motor.
Reactor is offline   Reply With Quote
Old 10-24-2011, 07:50 PM   #20
So you have data to back up your claim?
Old 10-24-2011, 08:53 PM   #21
Reactor
Drives: 1nz-fe
Scangauge can display LTFT value. I have one and clearly saw difference between running stock intake and AEM (i have 2006 xB)
AEM intake is slightly smaller diameter than stock runner which makes the MAF readings be higher than what they should be. So my ECU learned to run -5 to -7 Long Term Fuel Trim once it's off idle. With stock intake before it usually ran between +2 and 0.
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
