Old 11-23-2011, 09:18 PM   #1
TURBO YARIS
Your tire pressure is too low. Radial tires sidewalls are hard not soft like slicks. The wheel hop is due to the sidewall not supporting the tire enough.
TURBO YARIS is offline   Reply With Quote
Old 11-23-2011, 11:22 PM   #2
Viperoni
Drives: 2005 Toyota Echo
Wouldn't lowering the tire pressure reduce the tire's spring rate and increase it's damping?
2006 Saturn Ion Redline
Old 11-24-2011, 02:49 PM   #3
TURBO YARIS
I have no idea. But I do know that low tire pressure causes wheel hop on a radial tire.
Old 11-24-2011, 01:25 PM   #4
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Woww there thanks for the suggestions!
The present tires are Yokahama Advan048 which should be their best tires for street and strip. I tried with different pressures from 25 to 15psi and the less the pressure the more the bounce.
I will try for sure to soften the front and see what we get. Although I am trying to set at least the engine mountings to harder ones and probably I will go with super pro.
Old 11-24-2011, 01:25 PM   #5
^ As you've discovered, radials aren't designed for that. You have to use pressures that are correct for the tire, or you won't get results.
You can run slicks all the way down to 5 psi. They look like flats, lol. Do that to a radial drag tire and it just won't work well at all. I've tried both, I know.
Old 11-24-2011, 01:26 PM   #6
Parmas, do the simple stuff first. You have several good suggestions on the table to try before actually changing parts. Do those first, and one at a time, or you won't know what change made a difference.
Old 11-25-2011, 12:32 AM   #7
Parmas
Parmas's Avatar
Ok will do Cheers!
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
Bronzoil Cable Bushings for the Yaris/Echo now available! TWM Performance TWM Performance 58 03-31-2010 10:19 AM
Custom tags and custom vinyl ellenbetty Cosmetic Modifications (Exterior/Interior) 9 09-11-2009 03:13 PM
Custom install - Hertz, eD, JL - lots of pics The Spectacle In Car Entertainment + Electronics (audio / video / alarm) 34 04-14-2009 12:57 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
