Old 11-30-2011, 11:32 PM   #19
dawin2122
dawin2122's Avatar
Drives: TOYOTA YARIS SEDAN S ROJO
Originally Posted by TOLMACH View Post
you gonna need the hi-low level signal converter if you plan to use the stock HU
yep something like that
http://www.ebay.com/itm/HIGH-LOW-CON...item3f101ee7e9
dawin2122 is offline   Reply With Quote
Old 12-01-2011, 03:12 PM   #20
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
ok cool so what did you use to seal your box? liquid nails?
400 dollar yaris is offline   Reply With Quote
Old 12-02-2011, 03:03 PM   #21
400 dollar yaris
so the more air tight the better the box. correct?
Old 12-02-2011, 08:04 PM   #22
dawin2122
dawin2122's Avatar
ok i use a very strong wood glue but liquid nails is good to and screws and then for the corners inside the box caulking i hope this helps
Old 12-03-2011, 01:42 PM   #23
400 dollar yaris
the box/cabinet should be rigid and strong.. and yes.. no major air leaks / airtight overall .. I normally leave a small hole somewhere .. (temperature / pressure inside and outside the box issue)
how big of a hole ? if its to big couldnt it mess up the speakers?
Old 12-04-2011, 03:47 PM   #24
400 dollar yaris
and that should be small enough to not harm the speakers?
Old 12-11-2011, 07:08 PM   #25
400 dollar yaris
does the box have to have divided chambers inside the box? or can the two woofers just share the one compartment?
Old 12-11-2011, 08:10 PM   #26
dawin2122
dawin2122's Avatar
divided
Old 12-21-2011, 10:59 PM   #27
400 dollar yaris
ok so ive decided on this amp but i was wondering if the alternator can handle this much power anyone know the alternator ampage? or do you know if it will be able to power the amp. http://www.walmart.com/ip/BOSS-Audio...ifier/15780045
Two Twelve Inch Woofers with box for sale Daddie Y Items for Sale by private party 0 03-29-2010 03:00 PM
2 12 inch Speaker Woofers with Box babie y Items for Sale by private party 0 03-01-2010 09:54 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 01:45 AM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 05:43 PM
