#19 |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
Although I'm all about the aftermarket short-shifter, I'm not too enthuised about the whole stainless-steel-bushings-thing. I would much rather see a nice urethane set from Energy Suspension. I can imagine, since the steel bushings have NO play, that there could be negative side effects from using them. You should have a little play in the shifter- the rubber bushings, besides just insulating noise and vibration, keep you, the idiot human, from bending your shift forks and linkages when your shift angle is just a little off.
Just a thought.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
#20 |
#21 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
#22 | |
Drives: lil red 5-door Join Date: Sep 2006
TWM also has some aluminium replacement bushings.
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#23 | |
Drives: LB Join Date: Jul 2006
With stainless steel bushings, there is no play, so there are drawbacks. You will feel the road through your shifter. Some will say that for a daily driver it is pointless or annoying, but I personally like as much input from my car as possible. It helps you make decisions. The electronic power steering is already robbing you of that effect to a degree. Control is increased, but as Moose mentioned it comes at the price of risking long-term damage. If you're not an experienced stick driver, you may want to wait until you're good and comfortable before moving to steel bushings. If this isn't your first date with a clutch, however, you'll probably enjoy the sensation of actually feeling yourself sinking into gear. |
#24 |
aaaah i see, my bad there
![]() most interesting, then....
#25 |
OK. This is it folks. Cat is out of the bag... I hope I don't get yelled at for posting this, but it can now be found through the main web site, so I don't think I am sworn to secrecy anymore.
http://www.nonstoptuning.com/ProductsDrivetrain.htm 'Nuff said. NST FTW!!! |
#26 | |
The Million Dollar Question is still on the Table... WILL IT WORK WITH TWM's KIT?
#27 |
IT WILL! Your throws would be so short its insane!
The Two Million Dollar Question then... When is it "too short?" |
#28 |
#29 |
Oh jeez...
#30 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
what about the "TRD style" short throw, with our modified shifters? how short do you think those will be?
#31 |
I have a modified shifter and I'll likely be testing this new short shifter (which is tranny side) so I will let you guys know just how short it is.
#32 |
my only concern, after installing the TWM one, is that if it is combined with the TRD/CC shifter, it's going to be much too hard to push the lever into gear, there's already a lot of resistance.
But, wait and see
#33 |
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
Are you saying that the NST short shifter is on the tranny side?
Back in my Neon days we used to have a mod where we moved the pivot point on the gear selector arm in about an inch. That eventually evolved into someone making a new arm. I did that mod along with a true short shifter and holy crap where the shifts short. I think it was 2.5" total forward back motion. I will however say this. I had urethane bushings on the shift cables and they made shifting quickly difficult. I ended up putting the stock bushings back on the shifter side and leaving the aftermarkets on the tranny side and that helped a ton. A short shifter is a mod you can enjoy dozens of times a day.
ChinoCharles Intake supporter. |
#34 |
It is tranny side. I think if bushings were made they'd be stainless steel.
#35 |
![]() ![]() ![]() Drives: 2006 Yaris Join Date: Dec 2006
#36 |
return of the comeback
Drives: white '08LB..very nice,i like Join Date: Mar 2007
ey charles, any update on the shifter combo? thanx man!
| twm short shifter installed! | dngz | Performance Modifications | 115 | 08-02-2007 01:11 PM |
| TWM Short Shifter Boxing Week Blowout! | TWM Performance | Sponsors Classifieds Area | 2 | 01-08-2007 04:01 PM |
| November: Big Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 14 | 12-12-2006 10:50 AM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 03:37 PM |
| Custom short shifter | ChinoCharles | Performance Modifications | 13 | 08-20-2006 03:52 PM |
