Old 02-28-2012, 11:31 PM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
You might want to take a closer look. The automatic has a dipstick. As for the changing interval - This seems to get discussed at least weekly here.
The Japanese version that I have does not have a dip stick so there is no way of really checking the ATF fluid condition for me
Does anyone have any idea why the Japs would put a dip stick on one model of a particular locatoin and not the other????
tyrone_yaris is offline   Reply With Quote
Old 02-28-2012, 11:44 PM   #2
That's because you have the K41 CVT, which is completely different than the U340 automatic.
Old 02-28-2012, 11:53 PM   #3
tyrone_yaris
Oh i see. Do you know where I can get some info on drain / refill intervals for this transmission as the manual I have is in Japanese
Also if a DIY guide to do it is available on the net. Tried google but so far nothing.
Old 07-13-2014, 09:56 PM   #4
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
AUTOMATIC TRANSAXLE
Fluid capacity (drain and refill), L (qt.,
Imp. qt.): 2.5 (2.6, 2.2)
Fluid type:
Toyota Genuine ATF Type WS
Change automatic transmission fluid only
as necessary.
Generally, it is necessary to change
automatic transmission fluid only if your
vehicle is driven under one of the Special
Operating Conditions listed in your
“Scheduled Maintenance Guide” or
“Owner’s Manual Supplement”. When
changing the automatic transmission fluid,
use only “Toyota Genuine ATF Type WS”
(ATF JWS3324 or NWS9638) to aid in
assuring maximum transaxle performance.
Notice: Using automatic transmission
fluid other than “Toyota Genuine ATF
Type WS” may cause deterioration in
shift quality, locking up of your transmission
accompanied by vibration, and
ultimately damage the automatic transmission
of your vehicle.
Please contact your Toyota dealer for further
details.
I looked at the “Scheduled Maintenance Guide.” It never says when to change but it says when to check it. It says to check it pretty often.
I have 100K miles on my Yaris now. I bought it with 50K and don't know if the fluid was ever changed. I used the dipstick and saw the level was good. The color was purple, but a little dark. No metallic flakes or anything. I have no problems shifting (automatic).
Is it bad for the fluid to be a little dark?
Is there a good reason for me to change the fluid or even clean the filter and change the gasket as this website below instructs? (I know how much to use and to only use Toyota fluid.)
http://microimageonline.com/forums/s...ice-inspection
33.7 mpg in PA
bad is offline   Reply With Quote
Old 07-20-2014, 07:48 AM   #5
bronsin
bronsin's Avatar
IMO...no....unless the vehicle has been in a flood or subjected to unusually harsh operating conditions like trailer towing, subzero operation, or very hot climate.
I check my level once a year and inspect the transmission for leaks while up on ramps for oil changes.
Old 02-28-2012, 06:28 PM   #6
auxmike
auxmike's Avatar
CT, are we to understand that if we want to do this at home we just need buy 3 quarts for a DIY drain and fill?
Old 02-28-2012, 08:12 PM   #7
That's correct - About 3 quarts for just a drain and fill.
2007TRD posted a nice DIY on the Micro Image forum for doing either a drain and fill or a more detailed dropping of the AT pan to inspect the filter and magnets as well.
http://www.microimageonline.com/foru...ice-inspection
Old 07-12-2014, 08:40 PM   #8
bad
Winterizing
bad's Avatar
I see him talking about a Drain Plug Washer... have you seen this for sale online/ is it possible that my original one is fine and doesn't need replaced?
Thanks.
33.7 mpg in PA
Old 02-28-2012, 11:57 PM   #9
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
I changed mine at 81k miles , it was pretty dark compared to new fluid. Very simple, easier then oil change.
$8.99 qt from dealer and $3 for new gasket
yaris4062007 is offline   Reply With Quote
Old 03-07-2012, 01:27 AM   #10
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
can anyone take pic of the drain plug? i can't find it under the car...
caineroad is offline   Reply With Quote
Old 03-07-2012, 10:12 AM   #11
Old 03-07-2012, 10:19 AM   #12
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
bolt size is 10mm allen wrench or 10mm allen socket drain and fill 3 quarts is what i used but i dont think i used the full third quart check after 2 1/2 quarts and so on its a easy job
pennyracer is offline   Reply With Quote
Old 03-08-2012, 02:41 PM   #13
caineroad
caineroad's Avatar
Thank you very much indeed! time to do my fluid change!!
Old 04-24-2012, 11:28 AM   #14
oliveskate
Drives: Toyota Yaris
Also just wanted to include, that I would only use Toyota recommended fluid. I've seen plenty of time's when people use other transmission fluid, and it "burns" up right away, and the transmission doesn't shift as well. Spend the little more money and do it right. Don't forget to get a new gasket for the transmission plug. (Won' hurt to change it, every transmission service)
oliveskate is offline   Reply With Quote
Old 06-10-2012, 02:24 PM   #15
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
What is the gasket replacement you guys are talking about? Is there a gasket on the allen bolt you remove to drain? If anyone has a part number for it id appreciate it..
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 07-12-2014, 08:08 PM   #16
bad
Winterizing
bad's Avatar
35168C in CTScott's diagram above.
33.7 mpg in PA
Old 07-14-2014, 09:32 PM   #17
bad
Winterizing
bad's Avatar
When checking transmission fluid level, should car be in park or neutral while running?
33.7 mpg in PA
Old 07-20-2014, 02:35 AM   #18
nikonNUT
Drives: 2010 3 Door L
Shouldn't that be listed on the transmission dipstick?
nikonNUT is offline   Reply With Quote
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
