Old 02-08-2012, 02:34 PM   #19
thats what needs to be done but they gonna charge me just for them to do that although i have a friend that works there i just have to have him take my car for a day.. thanks scott.
Below is the kind of stuff it will tell you. This is a capture from my TechStream tool talking to my Yaris test bench. The AC ECU only has the ambient temp sensor connected, so I throw DTCs for the evaporator temp and the refrigerant pressure.
Old 02-08-2012, 03:48 PM   #20
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
thats so cool... would it detect pressure without compressor running though??
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 02-08-2012, 04:00 PM   #21
Yes. Here's a cap from my 2009 with the engine not running and AC off - 61.76 PSI
Old 02-08-2012, 04:16 PM   #22
marcus
toyota
marcus's Avatar
gotcha!!! ill will look into this as soon as it get warmer..
Old 02-08-2012, 07:15 PM   #23
bankrobber
Drives: 2007 Yaris Hatchback
At what temperature does "Hot" engine light come on
Has anyone had their Water Pump replaced? Carrot Top DIY / Maintenance / Service 48 03-20-2017 01:32 AM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
