Old 01-29-2012, 09:02 AM   #19
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
For the time being just get your 14mm wrench and tighten the bolt a little bit more. That might just stop the leak.
Next time you change the oil look at the drain bolt. Theres a special sealing washer on it. If its still leaks get another one from Toyota. Theirs will last the life of the car.
Oh wait a minute.
Start the engine and see if oil drips from the bolt. If nothing happens for 10 minutes you can pretty much forget about it. Hysterical service guy stirring you up.
Forgot about that...
or just replace it and forget all about it :)
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 01-30-2012, 12:10 AM   #20
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Thanks for the advice bronsin / yuri :)
Will check and decide accordingly
tyrone_yaris is offline   Reply With Quote
Old 02-18-2012, 03:32 AM   #21
irfancarman
Drives: Yaris 2008
How to change CVT Transmission oil Yaris 2008.
Hi everyone,
I need to change the Transmission oil on my Yaris 2008. My car manual is in Japanese and i am unable to find the English version. Can someone give me step by step procedure for the same.
Help is much appreciated.
irfancarman is offline   Reply With Quote
Old 02-18-2012, 10:45 PM   #22
Originally Posted by irfancarman View Post
Hi everyone,
Here is the procedure for changing the CVT fluid:
http://www.microimageonline.com/foru...T-Fluid-Change
In need of advice on maintenance on my 2.5 yr old Yaris Sedan Yari-Chan DIY / Maintenance / Service 29 07-02-2013 04:36 PM
Advice on long distant driving with a yaris signs General Yaris / Vitz Discussion 34 03-18-2010 01:14 PM
