Old 03-15-2012, 10:57 PM   #19
Viperoni
Drives: 2005 Toyota Echo
-1.5 and -1.4 degrees camber, front/back
0 toe all around
My outer edges wear way too quickly lol
2006 Saturn Ion Redline
Old 03-16-2012, 03:44 PM   #20
NJ Drive
Drives: 2012 Yaris SE
What tires are you running?
NJ Drive is offline   Reply With Quote
Old 06-26-2012, 12:14 PM   #21
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by NJ Drive View Post
I'll let you know shortly how much front camber can be had with the thinnest factory crash bolts for Yaris.
Any further info on this? I'm staying in Hstock as I get comp tires too cheap to ignore. I currently have aftermarket adjuster bolts and want to adjust them to the max that you can get w/ the toyota ones. Yes, I'm technically cheating, but the results are the same and I don't compete for points so don't really care. Just trying to keep from eating tires.
Cheers.
Front end alignment specs for lowered car JTDBT903 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-24-2011 09:59 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 12:04 PM
Alignment specs for 08 LB? detroiter DIY / Maintenance / Service 5 04-06-2009 01:56 PM
