Old 08-22-2012, 01:53 PM   #19
Originally Posted by sprayed1 View Post
Thanks for everything Scott, retested it per your method including rotation and it failed. Anyone who has a good one they would like to sell can PM me.
Thanks again Scott!
Here's the best deal I have seen ($75). The RAV4 and Highlander use the same clockspring as the Yaris.
I thought I was going to need one for Crashy2, but ended up just needing to replace the melted airbag connectors, so this was saved in my eBay watch list:
http://www.ebay.com/itm/2006-2007-20...cbfedc&vxp=mtr
Old 09-02-2012, 02:29 PM   #20
othater
Drives: 07SedanS06Taco
Everything has been fine with the airbag light in the cluster since I replaced the clock
spring back in May 2012.
I now have a flickering passenger airbag light on the dash.
I will see if there are any codes but I'm assuming since its flickering it might be a loose connection or something in that direction.
Any other troubleshooting suggestions?
othater is offline   Reply With Quote
Old 09-02-2012, 07:42 PM   #21
If the passenger one is flashing constantly, then you will see a code for something with the passenger occupancy classification system. Often, just unplugging and plugging back in the two connectors on the OC ECU (the little black box under the front edge of the passenger seat) will clear the issue.
Old 09-03-2012, 12:13 AM   #22
othater
I will try the connectors and reply with the results.
Should I have the ignition on when I disconnect and reconnect the connector?
Old 09-03-2012, 08:51 AM   #23
Do it with the ignition off.
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
Replace airbag in my 2007 Yaris uglyducklin DIY / Maintenance / Service 2 01-12-2011 02:53 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar opdmize Willing to Buy by private party 1 03-19-2010 01:01 AM
