Old 04-29-2012, 04:51 PM   #19
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You should be able to use a larger rated fuse.
The wire gauge is all about resistance. The less resistance/surface area the wire has, the better. 0 gauge is sweet, but if you have to use 4 gauge...
"4 awg 131 amps 1084 watts 1355 watts" -BCAE1.com
IMHO, the wire kit manufacturers say "1000" Watts to specify how much Wattage off your amps at minimum the wire can handle. Another example is what the Army uses for their 100 Ampere runs...They use 0000 gauge main insulated wires in a massively protected sleeve run. Take a look at this pic:
See the giant wire running across the front of the generator? That's our power wire. >:D In this instance we use two different types of power wire. This size and one like the roll that you can see in the background on the grass there. That's the "small one". The military rates the big wire run as 100 Amperes. *chuckle* It'll handle a wee bit more than that. Imagine what that one can handle when your 4 gauge can truly handle 100+ Amperes. To put it in perspective, these generators create 100 kW...of true power.
In my case I'm running 0 gauge back to the distro block, fusing the one in to three out and then running all 4 gauge power to each of my three amplifiers.
― Thomas Paine
Old 04-29-2012, 05:16 PM   #20
09sedan
Drives: 2009 yaris sedan
I see, i was quoted 220$ by a performance alternator builder that was posted on this site for me to send my factory alternator rebuilt to output 160 amps, if i go 0gauge it will leave me with room to expand if i decided to... Hmm.. I think i know what to do now :)
09sedan is offline   Reply With Quote
Old 04-29-2012, 05:58 PM   #21
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Tolm,
Why the fuse placement on the other side of the engine bay?
@packetrace - you mean the heat shrink? :)
I meant the techflex...where did you bought it ?
Interior:ALL red, black roof
Old 04-29-2012, 10:24 PM   #22
sqcomp
Roadrunner Jr.
sqcomp's Avatar
If you like that techflex, you'll trip on my speaker wire runs and my cooling fan run.
I get my techflex from various sources. Take a look at the seller, on eBay. That's a start.
― Thomas Paine
Old 04-30-2012, 11:16 PM   #23
CharlieBravo
CharlieBravo's Avatar
Drives: 2007 Yaris HB
Here's what I did with mine.
CharlieBravo is offline   Reply With Quote
Old 05-01-2012, 12:00 AM   #24
packetrace
packetrace's Avatar
Have pics ?
I really like the look of it!!
Old 05-01-2012, 01:32 AM   #25
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'll have to take pics of my sub wiring. It's a cool black & white checker pattern.
Oh and these pics are from early last month. It's a little more tidy now.
― Thomas Paine
Old 05-01-2012, 10:39 AM   #26
packetrace
packetrace's Avatar
WOW !! thats is very nice!!!!!!! WHat is the material over the roadkill ?
Old 05-01-2012, 10:56 AM   #27
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That is ensolite foam. Personally, after trying Ensolite, Dynaliner, and Overkill...overkill puts them all to shame in it's performance.
How's that for an opinion? :)
― Thomas Paine
Old 05-01-2012, 12:35 PM   #28
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
I'd be careful putting such a big fuse on that 4 gauge, it may actually be 6 gauge. Especially on such a long run.
Also here's some reading material on actual test on different brands of wire.
http://www.caraudio.com/forums/wirin...omparison.html
Old 05-01-2012, 12:45 PM   #29
_S7V7N_
_S7V7N_'s Avatar
Note if this wire ever came lose the first thing it would touch would be the hood of the car and cause a short hopefully one of the diodes to your alt will burn up before you car catches fire.
Old 05-01-2012, 01:42 PM   #30
packetrace
packetrace's Avatar
Thats perfect!! I treated my front doors with overkill so far...
I will receive ensolite this week and MAT...I'll order roadkill to cover the whole car! :D
Old 05-01-2012, 06:38 PM   #31
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That is why I ran my wire with the OEM bundling under the engine cover. If that's good enough for an OEM location, then it's good enough for me.
― Thomas Paine
Old 05-01-2012, 07:13 PM   #32
_S7V7N_
_S7V7N_'s Avatar
I know yours has to be a snug fit cause I used a good 4 gauge and it fit in there tight. I could imagine how 0 gauge must be. I feel comfortable running up to 150 amps on my 4 gauge just because the run is only like 3 feet.
I don't know why you'd wanna run that wire and put the fuse on the engine cover. I can understand wanting to show off that beefy wire but I wouldn't feel comfortable with all the vibration hitting that fuse constantly while the cars on.
Old 05-01-2012, 10:22 PM   #33
CharlieBravo
OEM run is still there. Fuse holder is zip tied to the cover. Its been 3 months and everything is still holding. Oh yeah, this was my first time attempting the Big 3. I do appreciate any and all comments though!
Old 05-01-2012, 11:22 PM   #34
_S7V7N_
_S7V7N_'s Avatar
The fuse is secured but what happens if your wire comes out to the left of your fuse ? That wire is not secured. Unless you are 100 % sure that screw will never loosen with all that vibration i'd try to find a way to secure it better. What you really worry about is a front end collision as long as your car shuts off you're fine but if it keeps running and that wire is knocked loose. Instant fire.
Old 05-02-2012, 11:19 PM   #35
CharlieBravo
Valid concern. I'll see what I can do this weekend.
A Hankook RS3 question... stevethegimp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-27-2011 05:16 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Yaris Pricing Question minervamoon New YARIS Purchase Forum 32 06-21-2009 05:26 PM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 11:12 AM
