Old 05-06-2012, 05:47 PM   #1
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
Wheel spacers
I've done some research on internet to find some good wheel spacers and have not find. About 20mm.
Do someone have them on their car ?
I have a 2008 HB.
Thanks!
new-yaris-owner is offline   Reply With Quote
Old 05-06-2012, 11:35 PM   #2
YAR1S
YAR1S's Avatar
I run the 13mm Penguin Garage hub spacers for the rear... as the rears are terribly sunken in compared to front. May not be what you are looking for.... but lots of people on here have them.
and no complaints :)
Here's their website:
http://www.penguingarage.com/HubSpacers/Spacer.html
-Jen <3
Old 05-07-2012, 07:04 AM   #3
racerb
Check out H&R Trak+ spacers, I'm sure Garm at Micro Image could get them for you.
http://www.trakplus.com/what
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-07-2012, 07:43 PM   #4
new-yaris-owner
Awesome, guys !
Is it hard to install ? since I don't really know how to dissemble the brake setup.
Thanks again ;)
Old 05-07-2012, 07:58 PM   #5
racerb
Not sure which one of us your asking, but if you have never done this sort of thing before. It might not be a bad idea to find a trust worthy Mechanic to do the work for you. The Penguin Garage unit requires removing the hub assembly, while the H&R spacers require installing longer studs. Both jobs take a certain amount of mechanical skill and proper tools. Which ever direction you chose, it will make a difference in track and fill out the fender wells.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-07-2012, 09:15 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
The PG spacers were actually fairly easy to install. The hardest part was getting the drum off to get at the bolts. Read up on the PG spacer threads around here to get a feel for it.
Old 05-07-2012, 09:47 PM   #7
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
My rims didn't clear the front disc brakes so I needed to order 5mm spacers. I got solid ones with a 54mm hole in the center to clear the front hub.
Old 05-08-2012, 11:24 AM   #8
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
hey, you guys mind posting a couple pics in here so i can get an idea on what size i should get?
Club SHIFT
Old 05-08-2012, 11:53 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
racerb
okay so 13 mm per side with penguin, and with hr you can get 90 mm total? So 116 mm total widening. Fun stuff, I wonder what that would do to handling?
Colin Chapman disciple
Old 05-09-2012, 03:14 PM   #10
33OH
Drives: '08 Yaris
^ Hub spacers, I don't think so, although those do look pretty similar to our design.
Wheel spacers, yes.
Old 05-10-2012, 09:04 PM   #11
racerb
I'm about ready to order a set of the Penguin Garage hub spacers just to see if they will also fit my '87 Celica rear hubs. That car has alot more space between tire edge and the fender lip and with standard offset rims even my 205/50/15 Toyo RA-1s rub the strut housings. I got away from crash bolts on the rear by making my own camber plates and can still get rub. Look forward to giving this a try and letting the world know if it works for other Toyota chassis!
Camber plates and strut adjustment knob......
Home built coil-over strut housing.......
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-11-2012, 03:59 AM   #12
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
I've always wondered if you get some spacer do you have to get a alinment?
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 05-11-2012, 06:42 AM   #13
33OH
Drives: '08 Yaris
Anytime you mess with the suspension components, it's best to get an alignment.
Old 05-11-2012, 07:15 AM   #14
enviri
enviri's Avatar
Drives: 2010 Yaris
hey if you can, measure the bolt spacing for the yaris hub while you're at it! I'm also interested to see what other cars are compatible with our rear hub (like certain gm cars with the 1st gen vitz)
Old 05-11-2012, 07:55 AM   #15
racerb
This is what I'm putting on the Celica to make rear alignment easier. Top is the '87 solid arm, bottom is the '95 adjustable arm, just gotta eliminate the inboard adjuster cam and we're good to go!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-11-2012, 11:50 AM   #16
tooter
play every day
tooter's Avatar
The bolt spacing is 4x100mm. Any spacer with that pattern and a 54mm hole in the center will fit.
Old 05-11-2012, 01:09 PM   #17
33OH
Drives: '08 Yaris
He means the hub bolts, not the lug bolts. :)
Old 05-11-2012, 02:07 PM   #18
Here you go: Yaris hub bolt measurements
25 mm Wheel spacers Rnankoo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 03-22-2011 07:58 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
