Old 02-23-2007, 02:21 PM   #19
ChinoCharles
Drives: LB
Sorry, I skipped right over that post.
Taken straight from the NST GB thread...
1. Regarding Light Weight pulleys vs Underdrive pulleys.
There is a ton of info about these concepts on our website and I will share just a tad with you here, you can look on our site or ask me on AIM and I can explain more. Also a lot of this info has been posted elsewhere on the internet by many of our customers and friends...
There are two benefits to NST pulleys. One is weight reduction, the other underdrive. Weight reduction leads to extra throttle response and a bit of HP and TQ being freed up and sent to the wheels. Underdriving from the crank pulley means sending less power to run the accessories, thus sending even more HP and TQ to the wheels.
The pulley we are offering you guys is of the first variety, it is an OEM diameter, lightweight crank pulley. We call this CR-Lite.
I will share some pics with you in the near future, but know this for now... The design of your crank case and your OEM crank pulley make it very difficult to design an underdrive crank pulley small enough to actually do any underdriving! If we could do more for you, we probably would, believe me.
Also, an underdrive crank pulley would slow your A/C and alternator by a tad, and many of you complain about your A/Cs being weak as they are. Most of you do not seem to want them any weaker.
90% of the time I am actually in favor of an underdrive crank pulley... but after doing some research I have come to the conclusion that for your Yaris a CR-Lite may actually be the best fit and best option.
Old 02-23-2007, 02:39 PM   #20
YarisGuy
Drives: 2006 Yaris
Originally Posted by CASTREX View Post
Chino would you share a bit of that TON of knowledge...?
I don't know if this has been answered here before... but do you happen to know why NSt didn't underdrive their yaris pulley? Their Scion pulleys are underdrived. Just wanted to know if there's a reason for this.
I asked about this as well. This has been discussed on page 2 of the NST group buy thread:
http://www.yarisworld.com/forums/showthread.php?t=3239
My understanding is that a smaller crank pulley would not fit well on our car.
YarisGuy is offline   Reply With Quote
Old 02-23-2007, 02:44 PM   #21
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Thanks guys...!
Can't wait for my pulley to come... just a couple more weeks
Old 02-23-2007, 05:01 PM   #22
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Okay, some of you still aren't convinced. Here is a couple more reasons.
First of all, weights...
ZPI pulley - 14.4 oz
NST pulley - 12.5 oz
Second of all, has anyone noticed that ZPI's pulleys don't come anodized? Hard anodizing does more than just make your pulley look pretty. It actually makes the pulley stronger. Aluminum is a rather soft metal by design, but hard anodized aluminum is stronger and will resist the sands of time better than untreated aluminum. ZPI will charge you 20 bucks extra to anodize your pulley. NST includes anodizing at no extra charge. They don't cut corners.
Charles,
Just a couple points here. I don't believe the NST pullies are HARD anodized. Correct me if I am wrong, I just hadn't seen that anywhere on the specs.
Anodizing is a chemical change on the surface of the alumnium. It does not actually make the metal stronger, just puts a tough wear resistant layer on the material. In hard anodizing, that layer is very similiar chemically to sapphire and it is more wear resistant than a regular anodized surface, or raw alumnium.
As I said above, the $5 extra for the anodized (hard or not) NST part is worth it in my book. It also seems the NST piece is a couple ounces lighter, which no one will ever notice one way or the other, but it is what it is.
Old 02-23-2007, 05:42 PM   #23
magoo_lc1
Drives: honda civic hatch
I say make your own choice. Do the homwork and buy the one you want. Competition only heps us all out. I dont think either would benefit us that much. Im not a engineer so there is a fantastic chance im wrong.
91 SE-R. R.I.P old freind
The influence of peers on individual behavior illustrates the seductive power of conformity
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at
magoo_lc1 is offline   Reply With Quote
Old 02-24-2007, 02:32 AM   #24
ChinoCharles
Drives: LB
Originally Posted by largeorangefont View Post
Charles,
Ashley, I am 99% sure I was told that these are in fact hard anodized, but I will double check that information.
Old 02-24-2007, 02:52 AM   #25
largeorangefont
Break'em off some.
If they are then all the better!!
Old 02-24-2007, 01:57 PM   #26
YarisGuy
Drives: 2006 Yaris
When in doubt, it might be wise to do a quick search of the manufaturer's website for information
http://www.nonstoptuning.com/pKitToyYaris.htm
Here's an excerpt:
Each NST Yaris Kit is carefully crafted from 6061-T6 aircraft aluminum, tested and balanced to high tolerances. Every NST pulley is hard anodized for exceptional durability and is a great item for use at the track or on the street. Available in your choice of colors: Red, Blue, or Graphite Gray.
Old 02-25-2007, 12:37 AM   #27
ChinoCharles
Drives: LB
There you have it.
Old 02-25-2007, 01:43 AM   #28
There you have it.
yeah, n00b, search, dammit, you n00b
Old 02-25-2007, 01:47 AM   #29
ChinoCharles
Drives: LB
Thomas, you can start shit when my STICKER GETS HERE.
ROFL!
Old 02-25-2007, 01:57 AM   #30
*whistles innocently, walks away*
Old 02-25-2007, 02:03 AM   #31
ChinoCharles
Drives: LB
We still love ya Thomas, you sexy French Yaris pimp you.
Old 02-25-2007, 02:14 AM   #32
dude get yourself to bed, you're starting to scare me
Old 02-25-2007, 09:37 PM   #33
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
NST!
elsteverino889 is offline   Reply With Quote
Old 02-26-2007, 12:37 AM   #34
evilreign
I've had NST products on my other ride and was very happy with them. Damn good value for the price. Plus their customer service was exceptional. I got very quick replies with any questions or support I needed.
NST FTW!
evilreign is offline   Reply With Quote
Old 02-27-2007, 09:54 PM   #35
From ChinoCharle's DIY Thread:
OEM Toyota Pulley - 50.00 oz
The DIY has been edited to include this information. Thanks for your PATIENCE.
ZPI - 71.2% reduction
NST - 75% reduction
IMO with this small difference there should really be no tangible advantage between the two, especially when you consider other pulleys and the flywheel, so it should really be a matter of personal preference
Old 03-04-2007, 03:34 PM   #36
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
is there any actual performance numbers for any of the yaris pully's????
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
NEW GROUP BUY: Yaris NST Crank Pulley (NonStopTuning) NonStopTuning NonStopTuning 224 05-17-2007 07:40 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
GROUP BUY - NST Crank Pulley riceboy Items for Sale by private party 35 12-30-2006 04:03 PM
