Old 02-28-2007, 02:13 AM   #19
RogueYaris
Drives: 2015 Abs Red
Those look great! I can't wait for them to stock other colors. I'm thinking of going with blue all around except in the trunk where I'll use the clear ones.
RogueYaris is offline   Reply With Quote
Old 02-28-2007, 02:30 AM   #20
DJ_Trizzak
DJ_Trizzak's Avatar
Drives: Yaris 07 Auto CE -Blazin Blue
do they only provide white? - ^^ya I want the blue 1's
myspace.com/djtrizzak | epik.ca | track1.ca |
DJ_Trizzak is offline   Reply With Quote
Old 02-28-2007, 08:54 AM   #21
fazali
fazali's Avatar
Drives: 2007 Toyota Yaris LB
Question- Does the lighting fade out after you close the door with the new bulb upgrade? Also- is the light overbearing?
Dallas, TX
2007 Yaris HB
Polar White
15" Black Feather Konig's
Viper Remote Start Alarm System
20% Window Tint All Around
fazali is offline   Reply With Quote
Old 02-28-2007, 10:43 AM   #22
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Good Question
Yes I too am interested to know about that.
eijikikimaru is offline   Reply With Quote
Old 02-28-2007, 10:49 AM   #23
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
I try to open the light cover but failed
someone know how to open it ??
jimcat is offline   Reply With Quote
Old 02-28-2007, 12:54 PM   #24
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The fader on the dome light still works with the HiLED.
Which light are you having trouble getting at jimcat?
To open the dome light, just pry it open (carefully) with a small flat bladed screwdriver.
The maplight opens the same way - with a screwdriver blade at the side - pry it down and it swivels toward the middle - then you just pop it off the two pivot points.
Old 02-28-2007, 05:18 PM   #25
Hileds
Drives: SUVs, Sedans & Exotics
Hello all,
I wouldn't say the white maplights are overbearing. Afterall, maplights are designed to help you read a map. So, they should be bright.
We do have the maplights (194s) available in blue, red, green and amber. However, white is going to be the brightest.
LEDs do work with faders. The voltage level controls the light output. HiLEDs do have circuit protection. So, at a certain point, an increase of voltage will not make it brighter and burn it out.
Hileds is offline   Reply With Quote
Old 03-02-2007, 08:21 PM   #26
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
Just got my installed, and I'm very impressed GJ HiLEDS.
My Car
My Garage
BokChoi is offline   Reply With Quote
Old 03-03-2007, 02:07 PM   #27
Violin
Violin's Avatar
Yay! Mine came today.
Old 03-03-2007, 06:45 PM   #28
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
And? Like or no?
Old 03-05-2007, 12:14 AM   #29
spkrman
Drives: 1
The stockers are already way too bright to be in your eyes IMO... they detract from vision at night, defeats the purpose... they really need to be more directional/focused.
Old 03-05-2007, 07:15 AM   #30
Violin
Violin's Avatar
Originally Posted by Chris07LB View Post
And? Like or no?
Kind of a mixed bag.
Here's the HiLED (on right) compared to a PIAA Super LED:
You can see the HiLED is many times brighter.
Here it is compared to the stock bulb:
The stock bulb is brighter and spreads better. The HiLED is a much nicer color though. I think I like it better.
The big improvement was in using the PCB-Dome light bulbs in my footwell lights:
Before:
After:
The disappointment was in the hatch light. The festoon fit in there, but I had to angle it to get it in. Only about half of the light gets thrown into the hatch area. It was brighter with the stock bulb. I can't see any way to modify the housing to get a better fit.
Old 09-06-2007, 08:53 PM   #31
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
NO LONGER VALID
OgDogg is offline   Reply With Quote
Old 09-06-2007, 09:02 PM   #32
mazultav
where can I get HiLed Products. You can't seem to order from the site, and I emailed them but got no reply.
mazultav is offline   Reply With Quote
Old 09-06-2007, 09:21 PM   #33
OgDogg
Gas Guzzler
OgDogg's Avatar
Call them. That's what I did. They shipped it out immediately.
Old 09-06-2007, 11:30 PM   #34
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
its a 194 what I don't get is, the wedge shape is the same as the o.e.m bulb but has a different number? kinda like 3057 and 3075 bulbs......am I assuming correctly to just order a few sets of 194 l.e.d packs and that is that?
Old 09-10-2007, 12:00 PM   #35
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i just emailed them on friday and had a response this morning....
Old 09-21-2007, 08:01 PM   #36
jenarae
jenarae's Avatar
Drives: No more Yaris!
I want some!
jenarae is offline   Reply With Quote
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
RS LED TAIL LIGHTS jimcat Cosmetic Modifications (Exterior/Interior) 11 12-01-2006 11:20 AM
GROUP BUY...Spiderlite X2,plug n play LED stop lights. eco Cosmetic Modifications (Exterior/Interior) 12 10-07-2006 11:05 AM
