Old 09-29-2012, 12:37 PM   #1
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
You should use a four, not three wire switch. The illumination should be isolated from the switching.
I just noticed that for both the DRL and non-DRL Yaris the fog relay coil is tied directly to the body ECU internally in such a way that it prevents the fogs from turning on except when it decides it is OK to. You would have to either do some surgery on the body ECU or use an external relay and rewire the fogs to it to override that behavior.
Scott,
The green wire is the trigger when the head lights lights go on, the violet loops to the other row. Looks like the Violet triggers the fog realy, and dash light.
Im having difficulty finding the wire that is live when the park/low/high get selected.
Do you have a wiring diagram for 2012??
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 05-16-2014, 01:57 PM   #2
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
Originally Posted by Absolutely Red 12 View Post
OK. DISREGARD my last post.
I forgot to turn on the ignition DOOOOHHH!
Jumping the purple and green wires at 3&4 made the fogs go on!!
The light on the dash also works!!
Time to get some taps, and wire the switch.
Now taking this one step further, how do I make it work with park, low, high.
CT Scott, thank you for the help, also in advance!!
I'm sorry, but, I do not work. I have Yaris 1.4 d4d, 1ND-TV, I put the fuse, I jump the wires at 3 & 4 made ​​the fogs not go on! I started the engine and the fogs not go on. What can I do? Any idea?
geoded is offline   Reply With Quote
Old 09-27-2012, 11:11 PM   #3
Absolutely Red 12
Asshole
Philips CrystalVision Ultra 9003, and H11 in the Headlights and fogs.
Old 01-13-2013, 09:02 PM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
So dumb question, and sorry to necro-bump, but all I need to do in theory is get the foglight kit, plug the lights into the pre-existing harnesses, then tap the two wires to the switch and install it in place of a delete plug?
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 01-13-2013, 09:11 PM   #5
Correct
Old 01-14-2013, 03:31 PM   #6
Shroomster
Shroomster's Avatar
Correct
Woot! Time to see what kind of deal I can get on an o.e.m kit from dealer through my job!
Old 01-25-2013, 08:11 PM   #7
Shroomster
Shroomster's Avatar
Looks like I will be getting a micro image fog light kit......Toyota fog kit is warranty replace only. PLUS get this: parts department showed me on screen that mid level LE trim does not/can not have fog lights installed from factory or aftermarket.....lmao......he sighed and laughed too, as that is what the screen inventory stated.....
Old 02-23-2013, 01:04 PM   #8
oohcory
Oohcory
Drives: 12' Yaris 2dr Liftback
Send a message via AIM to oohcory
has anyone with a 12' LE tried installing aftermarket fogs?
oohcory is offline   Reply With Quote
Old 02-23-2013, 02:15 PM   #9
Yes. Besides Absolutely_Red, a few others have as well.
Old 02-23-2013, 10:50 PM   #10
Absolutely Red 12
Asshole
All that is needed from the kits, are the lamps, fillers, and switch.
2012s have the wiring preinstalled.
As CTSott mentioned, the relay is integrated into the BCM.
You dont even need a switch!! If you want the fogs to always be on with the headlamps.
The lamps, if anyone is interested, are Camry interchange part numbers!!
Old 09-01-2013, 02:56 PM   #11
geoded
geoded's Avatar
Until after someone installed fog lights on 2012 Toyota Yaris? Pictures?
Old 09-02-2013, 01:07 PM   #12
geoded
geoded's Avatar
fog fuse
fog fuse
Old 09-02-2013, 01:13 PM   #13
geoded
geoded's Avatar
@Absolutely Red 12, You understand that you are including in FR FOG fuse?
Old 05-16-2014, 02:12 PM   #14
Jumping brown in 3 to green in 4 is correct for your TMMF built Yaris. The headlight switch must also be on and in low beam mode for the front fogs to light.
Old 06-17-2014, 11:36 AM   #15
geoded
geoded's Avatar
Wich wires turn on the foglights symbol in the instrument panel ?. Where is it located and what color wire is it? Thanks.
Old 05-16-2014, 02:18 PM   #16
geoded
geoded's Avatar
Yes, I did but it does not work.
Old 05-16-2014, 02:19 PM   #17
geoded
geoded's Avatar
maybe my car is different. what can I do?
Old 05-16-2014, 02:21 PM   #18
geoded
geoded's Avatar
but two? making pin 2?
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
