Old 03-07-2007, 04:53 PM   #19
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
Originally Posted by Nimble View Post
NEWS FLASH!!! A Yaris is slow even with a header, pulley, intake, exhaust, lightweight oil filter cap, high performance windshield washer fluid tank, color matched badges, less than 1/2 a tank of gas, and you cutting your legs off to save weight.
this is the kind of crap answer i didn't expect to see in this forum but its all good.........
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-07-2007, 05:01 PM   #20
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Expect it more with all the lame posts you've been making. Besides, haven't you read my avatar?
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 03-07-2007, 09:28 PM   #21
ChinoCharles
Drives: LB
Don't mind Nimble. He's a prick, but we tolerate him nonetheless.
Old 03-07-2007, 09:56 PM   #22
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yeah, don't mind the exaggerated response, It's just the roids talking.
Old 03-07-2007, 10:08 PM   #23
ChinoCharles
Drives: LB
We still love you Nimble. Someone has to slap the rice out of the forums. Guess its you now.
Old 03-07-2007, 11:13 PM   #24
Poorboy
Poorboy's Avatar
Drives: 07 liftback
Where do you get that high performance washer fluid at? How many hp increase
Poorboy is offline   Reply With Quote
Old 03-07-2007, 11:14 PM   #25
Nimble
Old 03-07-2007, 11:15 PM   #26
Nimble
12 to the wheels on rwd, 14 on fwd, we're lucky.
Old 03-07-2007, 11:15 PM   #27
Nimble
Old 03-07-2007, 11:31 PM   #28
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
dam, thats cold.
tekmoe is offline   Reply With Quote
Old 03-08-2007, 10:37 AM   #29
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
not a problem i deal with douche bags on a daily basis anyway........
Old 03-08-2007, 10:41 AM   #30
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Apparently since I'm a ZPI hater (not really) you might not want to try this little trick I learned from my SRT-4 days...
Toto- I believe I know why you're going to see a code if you just install on a straight pipe. Read on...
When I replaced my o2 pipe and my downpipe, we had two o2 sensors. One on the o2 pipe itself and one in the "cat" area. I decided to run a straight downpipe with a cutout. I understood that the computers would throw a code if the o2 sensors didn't detect a certain temperature difference between the two sensors. What I did was to buy a spark plug non-fouler, bore the inside out a little bit with a 1/2" drill bit. Why? Well, go ahead and try to screw in an o2 sensor to an 18mm non-fouler without boring the inside top out a little bit, you'll understand...the sensor just doesn't fit. When you take a bit of material out of it it will screw right on. After you bore that non-fouler out and fit it onto the o2 sensor, simply screw the non-fouler into the downstream sensor bung.
This backs the sensor off just enough to have it read a lower temperature like you'd have with a cat...like you're supposed to. It is my belief that when you look at a catalitic converter versus a straight pipe, you should notice that the o2 sensor dosn't go straight into the pipe's exaust stream as much as it would with a straight pipe. With my limited smarts on vehicle engines, I believe the temperature issue is why you'd see a code.
Now, I can find the how to for the SRT but it is really as simple as i've described it. I don't know the specific size of the stock o2 sensor on our Yaris. Sice I'm NOT going to be messing with the engine of mine...I leave this up to you guys.
On the old car, I NEVER threw a code with this little DIY mod in the year and a half I used it.
Thoughts?
― Thomas Paine
Old 03-08-2007, 11:02 AM   #31
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
I'm actually going for this mod in a couple of weeks:
Custom test pipe and the non-fouler trick.
Is a cheap mod (like $60 on a local shop) so if it goes wrong I'll just go back to the original set up.
I don't want to loose any low end power (this is a DD after all) so I don't want to go for a bigger pipe. I'm just curious to see how the car reacts to a better flowing exhaust. I think there is no gain on going for a larger diameter pipe, been this a N/A 1.5L but maybe we could get something out of an improved flow.
Let you know how it goes...
Old 03-08-2007, 11:15 AM   #32
ChinoCharles
Drives: LB
I'll see if Baskin can get a hold of his guy in Toyota... maybe we can grab their coursework on their O2 sensors and see whats going on.
CASTREX, thats what I'm talking about!!! Go 2.25" though, make it a tad larger.
Old 03-08-2007, 11:19 AM   #33
CASTREX
CASTREX's Avatar
Some thing else exhaust related that I've been thinking about lately...
I kind of like the Chinocharles filosofy of cheap mods for a cheap car
Looking at the pics of theTRD muffler, it just looks almost the same as the OEM muffler with a nice polished tip. I guess the difference must be on the inside.
So, any one thinks that could be possible to open the OEM muffler and take some guts out of it? I dunno how that muffler looks on the inside, but anyone thinks that this could be done? Improved flow and quite at the same time!
Old 03-08-2007, 12:26 PM   #34
Nimble
Right, guys like you...you know car salesman....typical douche bags.
Old 03-08-2007, 01:09 PM   #35
sqcomp
Roadrunner Jr.
sqcomp's Avatar
FYI, those non-foulers should only be $5-$10 for two of them.
― Thomas Paine
Old 03-08-2007, 04:26 PM   #36
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
Thoughts?
This is exactly what I was talking about in my post. It's worked for me on several cars. I coined the term "Ghetto Sim" on thevboard for this mod.
Dragonacc is offline   Reply With Quote
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
My Yaris IS SLOW David81 Performance Modifications 47 08-08-2006 02:34 PM
