Old 10-11-2012, 01:29 PM   #19
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
The fuel gauge has nothing to do with the ECM. The fuel gauge is directly connected to only the instrument cluster (of which they can not reflash). If something changed with your bars after the reflash, then it has to do with a change in fuel consumption.
now im confused.. my average mpg before toyota had the car was 1st bar falls off at around 110km, 2nd bar 190-200km... after toyota my km was 165km n 2nd bar was gone.. and my average is 175 km for that 2nd bar to fall off.. but over all my mpg is the same for the whole tank. toyota must have done something >> but for now i dont really care..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 10-11-2012, 02:44 PM   #20
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
usa made Toyotas are crap
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 10-11-2012, 05:17 PM   #21
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Actually they only have to pop the cover on the driver's arm rest to work on the switch assembly, which is this chunk:
Attachment 48767
This is a picture of a burnt one from an article on repairing them (http://www.toyotawiki.org/index.php?...indow_switches):
Attachment 48768
Basically the switches are switching high current (~10 Amps) to the power window motors. They are directly doing the switching, rather than switching the coil on a relay (as is done with most of the other high-current switching on a vehicle). So, if the contacts are coated with something that is conductive or becomes conductive over time (the carbonization mentioned in the recall article), current flowing through the resistive (partially conductive) material will make it heat up. With the power windows being fused with a single 30A fuse, you have the potential to create up to a 420 Watt heater (14 Volts x 30 Amps) before the fuse blows.
I've repaired switches like these since I worked for Volvo in the 80s.
The carbon is NON conductive, thats why the switches stop working.
Wiping off the NON conductive carbon, allows the switch to contact.
BTW Pretty much all window switches do this wether they use a relay or not..
The grease used in Toyota switches become carbonized, and conductive.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 10-11-2012, 06:03 PM   #22
Billiam
Drives: '10 White Yaris 4D LB
And what does this idiotic statement have to do with the 7.4 million Toyotas worldwide that are being recalled?
If you want to enjoy your car, stay off of the internet.
Old 10-11-2012, 06:11 PM   #23
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Ha! Manual windows FTW!
Killchain is offline   Reply With Quote
Old 10-11-2012, 06:18 PM   #24
Carbon is conductive and generates a great deal of heat when current is run through it, hence carbon-arc lighting or carbon-arc welding.
Old 10-11-2012, 06:49 PM   #25
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Did you miss the memo that the Yaris/Belta/Vios/Vitz are manufactured and assembled in Japan?
Old 10-12-2012, 11:42 AM   #26
narly charley
Drives: 2010 Yaris "L" 5 Speed
This is why I like cranks and manual locks. There are less moving parts and components to malfunction, break, or wear out.
narly charley is offline   Reply With Quote
Old 10-12-2012, 12:41 PM   #27
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I didn't buy a Hyundai because none of them came with crank windows or used real non-electronic keys to unlock the doors. I'm so glad I held out for the old trailing edge technology.
Old 10-12-2012, 01:16 PM   #28
bronsin
bronsin's Avatar
Right ALL power window switches do this. So ONE incident triggers a recall costing millions which does NOTHING to improve safety.
Old 10-12-2012, 03:52 PM   #29
nookandcrannycar
Old 10-12-2012, 11:52 PM   #30
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Ha Ha ... I am sure there are 2 people here on YW that are saying "I told you so" re this recall. I am still a fan of power windows, this doesn't change anything for me.
edmscan is offline   Reply With Quote
Old 10-13-2012, 01:04 AM   #31
nookandcrannycar
...more than two....but definitely fewer than fifteen....so, you're right, not very many.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2009 Toyota Yaris Recall #09V223000 alan1828 Canada 3 05-31-2010 08:45 PM
